Author Topic: Found a '76 CB750F1 - fair price? [edit - bought it, got it running]  (Read 4350 times)
Offline Cevan
I've found a '76 CB750F1 locally.  I'm going to look at it in the next few days.  The guy reports it ran a couple of years ago but it's just sat since then.  He thinks it has charging issues (shocking, I know).
From the photos, it has what appears to be ComStars and 4 into 1 exhaust.  Except for the tank (it has a '78 tank on it), all the parts appear to be there.
I've been looking for a new resto project (cafe maybe).  Assuming it needs a full restoration, what's a fair price to pay?
« Last Edit: July 29, 2011, 01:39:20 PM by Cevan »
Offline david 750f
  • 1976 CB750F
Re: '76 CB750F1
« Reply #1 on: July 14, 2011, 01:40:23 PM »
Get the frame VIN and engine serial numbers so you can check what year it is.
Comstars came on the 77/78 F models not on the 76.
1976 CB 750F
Offline crackerbat
Re: '76 CB750F1
« Reply #2 on: July 14, 2011, 03:53:28 PM »
paid 500 for my 76 750f1 that i picked up about a month ago.
It sat for about 3 years.
Offline Cevan
Re: '76 CB750F1
« Reply #3 on: July 14, 2011, 07:19:13 PM »
Here are photos the owner sent me.  I will check the VIN#.
Re: '76 CB750F1
« Reply #4 on: July 14, 2011, 07:26:54 PM »
Good luck with that.
Offline brandEn
Re: '76 CB750F1
« Reply #5 on: July 14, 2011, 07:28:58 PM »
Looks like you have a bastard there. The 77-78F's came with Comstars and they had dual disc brakes. Yours obviously has a single disk so not sure about that. Also the gas tank on the bike pictured here is from a 77 or 78 K model. The F tanks are slimmer.
Offline BeSeeingYou
Re: '76 CB750F1
« Reply #6 on: July 14, 2011, 09:13:07 PM »
That is a 75/6 F with a few "other" parts as others have posted.  For a resto I might find another but may be a good candidate for a cafe.  Maybe $300.
Offline crackerbat
Re: '76 CB750F1
« Reply #7 on: July 14, 2011, 09:44:16 PM »
yeah 2-300..
then sell me the side covers >.>
Re: '76 CB750F1
« Reply #8 on: July 15, 2011, 02:47:22 AM »
yeah 2-300..
You can buy top quality side covers on this site and very well priced.....I have a couple of sets and they are great.... Look up Frankenbike.
http://forums.sohc4.net/index.php?topic=74022.1500
Look at post 1508....
Offline Cevan
Re: '76 CB750F1
« Reply #9 on: July 15, 2011, 04:50:53 AM »
$2-300, that's kinda what I thought.
Offline Cevan
Re: Found a '76 CB750F1 - fair price?
« Reply #10 on: July 16, 2011, 07:18:31 AM »
I looked at the bike this  morning and we negotiated a price:  $50.   :D
It comes with the original tank which needs serious restoration and a title.
I'd like to get it running to sort out any engine/trans issues before I tear it down.  It hasn't run in a couple of years so I figure put some oil in the cylinders and thru the valve adjustment covers and turn  it over before firing it up.  Anything else I should do?
bollingball
« Reply #11 on: July 16, 2011, 09:53:32 AM »
A couple of years? carbs going to have to do them sooner or later use a aux fuel tank old plastic lawn mower tanks work good. New oil & filter.Air filter. Oh hell just do a 3000 mile tune up.
Offline BeSeeingYou
« Reply #12 on: July 16, 2011, 08:06:25 PM »
For $50 I would say you got a good score there.  I have seen folks pay more for a lot worse. ;D
Offline bender01
« Reply #13 on: July 16, 2011, 08:07:40 PM »
Jump up and down!
$50 s a fair price. What state are you in for the title? Maybe a friend of yours from a non title state could send you a bill of sale....  :-X
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
« Reply #14 on: July 16, 2011, 08:15:12 PM »
He stated that it came with a title. Whoops wrong quote
Offline MoMo
  • Ride like you're invisible
« Reply #15 on: July 16, 2011, 08:19:34 PM »
Any sohc with a title is worth 2 to 300. Nice find...Larry
Offline bender01
« Reply #16 on: July 16, 2011, 10:32:08 PM »
I misread. Thought it needed a tank resto and a title resto.
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Tews19
  • I am no
« Reply #17 on: July 17, 2011, 10:12:36 AM »
Nice find for 50 bucks.
1970 Honda CB750 survivor.
Offline Ricky_Racer
« Reply #18 on: July 17, 2011, 10:57:33 AM »
You done good!  Throw a tarp underneath. Soak 'er down in PB Blaster for a couple three days. Strip everything off that you don't want and toss it in a pile. Offer those parts, if they're usable, in this site's For Sale section. Trash or recycle the rest, then Rock 'n Roll to your new cafe bike!   :)  RR
Offline Scott S
« Reply #19 on: July 18, 2011, 03:49:51 AM »
 Good score and PERFECT for a cafe' conversion. At least you won't be dismantling a nearly complete, stock bike. Don't get me wrong...love the cafe' bikes, but that bike is PERFECT to use as a starting point for one!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Cevan
Re: Found a '76 CB750F1 - fair price? [edit - bought it, got it running]
« Reply #20 on: July 29, 2011, 01:52:47 PM »
Quick update:  I wanted to get this thing running and see how it ran and shifted.   I removed the airbox and found a pretty crappy filter inside.  I had a Fram CA3681 lying around and with a little bending, got it to fit inside.  The float bowls had nice clean gas inside so that was a good sign.  I check the coils and they were good.  The solenoid needed to be pulled apart and cleaned.  After that, the starter worked.
I had to remove the front caliper piston and seal and clean them up.  Reinstalled and a quick bleed.  Seems to work ok.  Good enought for my 1/4 mile long driveway.
Onto the points.  The PO had new spares so I replaced them.  I checked the advancer while I was in there and that worked smoothly.  Did a static timing.  I popped in fresh plugs and a new battery.  Both tanks that came with the bike were nasty so I pulled the tank off my CB360 and stuck it up on top.  Hit the starter and it fired right up.  I love Hondas!
Surprisingly it didn't smoke.  It actually idled nicely.  I've taken it up and down the driveway a couple of times and shifted thru the gears.  So far so good.  I'll probably get it warmed up again and do a compression test.  Then the tear down begins.
Offline Tews19
  • I am no
« Reply #21 on: July 29, 2011, 02:02:33 PM »
That is awesome. What are the plans for it now?
Offline fatkid
  • you cant undo whats already been done. so just ask
« Reply #22 on: July 29, 2011, 07:49:08 PM »
man more and more f 750 are coming out of the wood work i love it . good luck my man great find
« Reply #23 on: July 29, 2011, 08:00:00 PM »
Great deal! Buy another good tank, trying to rested those old nasty tanks is not worth the time or money.
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #24 on: July 29, 2011, 08:22:15 PM »
I'm picking up a '78 CB750 tomorrow. Po says it needs a seat,
battery and exhaust. Will take some pictures of it when I get it home. So you guys can tell me what you think. I beat out 8 other bidders, hope no one from this forum, sorry.
        Doug
