O.K.... I'll try this !
3 easy steps to follow to adjust your cam chain tension.....
1. Unscrew the two inspection covers ( 17mm wrench ) over the #1 cyl. tappets and rotate the crank until the 1-4 'T' mark is visable in the timing plate 'window'. Try to move the tappets, if they will move freely side/upwards your ready for the next step. If tight against the valve springs, then rotate 1 full turn until 1-4 'T' mark comes around again.
2. Continue to turn the crank slowly clockwise from the above 'T' mark until the round spring post is centered in the 'window' ( you will see the end of the spring wrapped around it ). Stop turning here !
3. Loosen the tensioner bolt ( 10mm head ) and it's locknut 3 or 4 turns. Tighten the bolt and 'snug-up' the locknut .
Mr. Honda says that your camchain is at it's loosest when the crank is turned 15% past the top of the pistons travel after the compression stroke. At 15% past TDC, it just happens to be where you can see that spring post in the 'window'.
When you loosen the 10mm (head) bolt , the spring on the tensioner automatically 'shoots' the tensioner shoe forward to take-up any slack in the chain and re-tightening the bolt sets it in its new position... got it
