Author Topic: Carb leak at fuel "T" tubes (cb750 k6)  (Read 1903 times)
Offline DHolbrook
    • ArtSite
« on: July 17, 2011, 06:34:55 PM »
Hello all, after only about a week of sitting waiting to fix a clutch cable, my carbs were all leaky and I found the problem to be above the gasket line at the metal "T" fitting which separates the fuel into carbs 1/2 or 3/4.  My carbs are otherwise clean and so I'm wondering what the easiest way is to remove my two metal "T's" to install new o-rings on them?  Do I need to pull all the carbs off, or can I just pull off the outside carbs (1 and 4)?  Any help is appreciated, here is a pic. of the fitting…    Bike is a CB750 K6.  THANKS!
Re: Carb leak at fuel "T" tubes (cb750 k6)
« Reply #1 on: July 17, 2011, 09:35:37 PM »
You'll have to pull off the rack to get at the screws to release the 2 outside carbs, at the least.  :(
You'll need 4 O-rings of 2x8mm size for each T (8 total). If you can't find them locally, let me know: I can send a you a set of 8 for $6 (includes shipping), since I bought 40 of them a month ago. Try Ace Hardware: they are expensive, but often have them in stock.
« Last Edit: July 21, 2011, 04:19:22 PM by HondaMan »
Offline DHolbrook
    • ArtSite
« Reply #2 on: July 19, 2011, 03:30:26 PM »
Thanks all!  Guess you know what I'll be doing this weekend.
KingCustomCycles.com
« Reply #3 on: July 19, 2011, 06:25:32 PM »
There may be a "sweet" spot where they can be positioned to not leak.  I have also had them, and petcock seals, spontaneously quit leaking after being exposed to fuel for 1-3 days.  After 3 days, I start ordering rubber bits.
Offline DJ_AX
« Reply #4 on: July 19, 2011, 07:51:44 PM »
+1
and I like a leak that fixes itself! :)
Offline 70cbk0
« Reply #5 on: July 19, 2011, 08:05:55 PM »
Yeah, I think not available from Honda, but I just googled O-rings locally, found a source, and bought a bunch for $5
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
« Reply #6 on: July 20, 2011, 02:17:36 AM »
most bearing service/shops have the o rings you need,.20c each on those here.
Offline DHolbrook
    • ArtSite
« Reply #7 on: July 21, 2011, 03:26:15 PM »
Cool thanks!
« Reply #8 on: July 22, 2011, 12:13:53 AM »
anytime i have to get o rings for something i always get a few,take the tee and the carb to the shop when you go down even,i use a little petroleum jelly when fitting them back together,just work the o ring in your fingers with the jelly then wipe it off dont glob it all over itll attract grit etc.
