Author Topic: R&R pistons / cylinders with engine in bike  (Read 830 times)
Offline Goldbug
« on: July 18, 2011, 08:12:45 AM »
Bike: 1973 CB500
Looks like my #4 may be toast. I have the top end from my old engine which was fine (it was the bottom end that leaked like crazy). Since I just put the new (to me, obviously I got ripped off here) motor in with the non-leaking bottom end I wanted to R&R the cylinders and pistons with ones from my other engine- basically get the best parts from both motors. I don't want to bore or hone anything, just swap the offending parts, change gaskets and be done with it.
The FSM shows that R&Ring the pistons is possible with the engine in the bike.
Any gotchas I should watch out for? Tips? Tricks?
Offline Lostboy Steve
Re: R&R pistons / cylinders with engine in bike
« Reply #1 on: July 18, 2011, 10:46:13 AM »
I only know one thing.... You may as well measure and hone. Its not worth having to do it again.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #2 on: July 18, 2011, 12:40:23 PM »
use new gudeon pin(wrist pin)clips,dont drop anthing into the open case,buy a telescopic magnet for just in case you do.
