Before firing it up I noticed the two lines coming from the carbs and only one port on the fuel tank, that's what brought me to this site. I put gas into the correct line on the carb.
Well I fired up the bike with no air box #1-3 carbs were leaking fuel from the overflow tubes and the #1 carb was also pouring fuel from one of the small brass tubes pointing in towards the air box (intake portion of carb). I removed the carbs and checked the float levels, which I should have done before hand
![Roll Eyes ::)](http://forums.sohc4.net/Smileys/default/rolleyes.gif)
. #1 float 7mm, #2&3 10mm and #4 13.64mm. I set all 4 too 14.5 mm. After work I'll put the carbs back in and fire it up.
