Thanks Syscrush!
So even though I've been advised against it, I installed a Dyna-S electronic ignition this morning. I took my bike over to a friends place who's been fixing up bikes for years, and is a retired electrician. He was going to help me set the timing on the points system. Just ended up that we tried the Dyna-S since it is so simple to install and I have to say, there was a noticeable increase in performance. The engine runs smoother at lower RPMs and had more pull on the highway too. I guess my timing must have been out before. I'm very happy with it now and feel confident the system won't fail.
As for the front wheel drag, yes I can spin the wheel by hand pretty easily. It's not 100% free, wasn't sure if there was a typical amount of drag or not. Glad to hear its not that uncommon.
Almost time to leave for the trip, only two more days to prepare! The same guy I just mentioned is also helping me check the valve clearances on Monday evening and I'm picking up a nice used stock seat to replace the brutal DIY seat my bike came with. Only thing left to do is set the cam chain tension, check the primary chain tension, and strap my gear onto the back. Can't wait!
Aladinsane07 - Turns out that the PO had switched a wire colour inside the harness. When I disconnected everything to pull the wires out of the old bars, I didn't label the wires because they are all colour-coded. Should have been simple to re-connect everything. But I didn't notice that there was one black wire coming out of the bars that was connected to a green stripped wire inside the headlight assembly. When I went to re-connect everything, I had no way of knowing the wire colours were off. The wiring diagram called for a green wire to engage the solenoid, but on my particular bike it needed to be a black wire. Took a lot of head scratching to discover they had been switched.
Also, anyone know where you can buy replacement hoses that connect the oil tank to the engine? I have a small oil drip coming from one of them. Nothing to be concerned about, but they should be replaced sometime soon. I tried my local Honda dealer, they told me they were discontinued...
