Author Topic: Cheep OEM Fuse Alternative  (Read 631 times)
Offline zackblack
  • Give my creation... Life!
« on: July 20, 2011, 04:58:23 PM »
Well I plugged in my new battery today and burnt up my wire harness...
...I was looking for wire and new male/female plugs when I came across something better than the OEM "glass barrel" fuse that came with the bike.  It costs three dollars at Canadian Tire:
« Last Edit: July 20, 2011, 05:00:17 PM by zackblack »
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: Cheep OEM Fuse Alternative
« Reply #1 on: July 20, 2011, 08:02:47 PM »
I have those on my fuses.  The PO had switched To blade type fuses, but with non-sealed, uncovered female blade ends with the fuse shoved in there.  I swapped these in to give it some protection from the elements.  So far so good.
Next step would be HondaMan style fuse block, for a little added stability.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
