Author Topic: fmctm1sw Ugly 750 K3 (project name: Mr. Yuk!)  (Read 114469 times)
Offline fmctm1sw
Re: Ugly 750 K3 (project name: Mr. Yuk!)
« Reply #25 on: August 10, 2011, 06:30:58 PM »
The fork seals put up a struggle.  I ended up using a torch on them to loosen them up a little.  Then we used a PVC pipe to tap the new seal down into the tube.  The forks went back together without any issue.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #26 on: August 10, 2011, 06:33:15 PM »
Here's some work on the front end bits and some reassembly photos.  Not real good pictures but I'll get some better ones when I get it out into the sunlight.
« Last Edit: August 10, 2011, 06:36:34 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline DedHed
  • Boob
« Reply #27 on: August 11, 2011, 06:06:07 AM »
Nice... It looks like the gaters are in good condition. I had to scrap mine, I believe the PO cleaned them with brake fluid or something as they were mostly disintegrated when I got  the bike. It also looks like the ears cleaned up pretty good as well, how are the inside of the ears?
CB750 K4
Offline fmctm1sw
« Reply #28 on: August 11, 2011, 11:12:18 AM »
Mine were too.  These boots are courtesy of someone here.  The insides of the ears are a little rough.  I wiped the fork tubes with a little bit of transmission fluid and they went on without too much force.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #29 on: August 13, 2011, 05:48:37 PM »
Some more bits from the front end.  I went back to stock handlebars.  They aren't in as good of shape but oh well.  I fished the wires through the handlebars with tape and an old clutch cable.  Unfortunately, the high/low beam switch disintegrated while I was pulling the other side through.
« Last Edit: August 14, 2011, 08:23:18 AM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #30 on: August 14, 2011, 06:07:23 PM »
Here's some more work on the front end.  The fender cleaned up real nicely, unfortunately you can't see it because of my camera.  I put the low handlebars back on it so I can yank it around the garage.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #31 on: August 27, 2011, 09:21:52 AM »
Got a set of original length shocks yesterday and cleaned them up a bit.  Not show quality but they cleaned up respectably.  I really don't think this bike will look too bad once I get the motor out and cleaned up.  Though the paint job will probably be an "FM spray job."
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #32 on: August 27, 2011, 01:35:46 PM »
I decided to forge ahead with motor removal.  I got it out myself using the same technique I used on my 550.  I had to remove the oil filter housing and custom tappet covers I have.  It took a little wiggling but between the two rollers and a hydraulic jack I got it out.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #33 on: August 27, 2011, 01:38:31 PM »
more engine photos..
« Last Edit: August 27, 2011, 06:51:36 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline DedHed
  • Boob
« Reply #34 on: August 27, 2011, 01:52:50 PM »
Dang.... All I did was change the oil this week....
I'm still watching.
Phil
CB750 K4
Offline fmctm1sw
« Reply #35 on: August 28, 2011, 01:08:06 PM »
More motor work.  It's hard to believe there was a SOHC 750 motor under all that flaking black paint  :)
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #36 on: August 28, 2011, 01:11:08 PM »
That was the work of aircraft stripper, brillo pads, a small pick and garden hose.  I'm going to hit it with my soda blaster after I take a break...
*edit* last photo of the day at the end.  The jug and head are really stubborn.  Since compression was low on #4, I have to take it apart anyway so I'll just blast them at a booth.
« Last Edit: August 28, 2011, 04:33:35 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #37 on: August 31, 2011, 05:40:14 PM »
Engine disassembly.  The plan is to refit the valve cover and sand blast the jug and head (hopefully Friday).  There was also an issue with compression on #4.  I heard (and smelled) air hissing out of the oil tank so I'll get a look when I get it apart.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #38 on: September 01, 2011, 07:06:35 PM »
Getting the top end apart was relatively straight forward, not much trouble there.  I was hoping the issue with compression on #4 would be readily apparent when I got the top end apart.  I was not disappointed.  The compression rings on #4 were completely stuck in the grooves.  Probably not coincidence that the deposits on the cylinder #4 look different than the others...  Tomorrow I blast and with a set of rings (if I can't un-stick #4) and a top end gasket set I should be in business...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #39 on: September 02, 2011, 06:20:17 PM »
Some shots of the head and jug.  I'm pretty happy with the jug but the head needs a little more work.
« Last Edit: September 02, 2011, 06:22:03 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #40 on: September 03, 2011, 08:09:00 PM »
That whole "try to free the rings" thing was definitely not going to work.  So I broke them out piece by piece.  The piston really doesn't look that bad, I got some extreme closeups (too close I guess).  Got a top end gasket set on the way too.  Need set of rings though...
« Last Edit: September 03, 2011, 08:10:48 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #41 on: November 11, 2011, 05:42:17 AM »
Did you get rings yet?
Offline fmctm1sw
« Reply #42 on: November 11, 2011, 04:50:57 PM »
Yeah, I've been slacking on this bad.  I had it honed and put new rings in it but found out the top of my valve stems were banged up.  I'm looking at getting a set of lash caps but that 650 I'm working on has been taking up all my time.  The motor is still on the floor next to the bike..
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #43 on: November 12, 2011, 03:22:19 PM »
Oh...sorry to hear. Seems like one issue leads to another.  Good luck.
Offline fmctm1sw
« Reply #44 on: January 16, 2012, 05:04:45 PM »
Man, it's been a while on this one...  I decided to go the route of lash caps to address the nicked up stems I had.  Originally I was just going to put the caps on and reassemble it seeing that compression was good everywhere but cylinder #4.  I started noticing little specs of sand from when I blasted it a while ago though so I decided to take all the valves out and make sure everything was clean.  I had trouble getting the small (inside) springs out, I literally unscrewed one of those springs from the stem seal.  The seals were enormous compared to what came in my gasket set.  I didn't know what to make of it so I replaced all of them with the ones that came in my gasket set.  Lapped the valves too.  Everything is cleaned up real good and torqued down to spec.  One note about the lash caps.  If you decide to go that route, you'll want to shorten your valve stem by the thickness of your lash cap.  If you don't, your tappet will not land square on the cap.  It is mentioned here by someone (Mrieck?) to shorten the stems, but I chose not to do so.  Now I understand why I should have done it.  I'm going to go with it for now, everything is torqued back down to spec.  No trouble at all getting it back together.  I was surprised how easy it really was.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tews19
  • I am no
« Reply #45 on: January 18, 2012, 08:09:38 PM »
Very interesting build. Your methods seem a lot like mine. Subscribed
« Last Edit: January 19, 2012, 06:05:44 AM by Tews19 »
1970 Honda CB750 survivor.
Offline lucky
Re: Ugly 750 K3
« Reply #46 on: January 18, 2012, 11:17:36 PM »
Put in some more work on the rim today.  Between aircraft stripper, a brass wire brush, carb cleaner, a razor blade, and water spray I feel I got it back to respectability now.  Some rough spots on the rim still, looks permanent :(   I figure I'll try hitting the spokes with some kind of emery cloth or something.  Something I can hold in my hand an pull back and forth around them.
Use #000 steel wool on the spokes with WD40.
Be very carful where and how you store the steel wool. Put it inside of a metal can.
It can burn your house down if stored improperly.
If the steel wool gets damp and then it is on a shelf and the sunlight hits it, it rusts(oxidizes), so fast it actually combusts.
Offline fmctm1sw
« Reply #47 on: August 19, 2012, 11:36:24 AM »
Warning: this topic has not been posted in for at least 180 days.
Unless you're sure you want to reply, please consider starting a new topic.
Wow, a 180 day warning on a project thread.  I've totally slacked on this.  The selling of my CBO 350F has motivated me to get back to this.  I got the motor back in it.  The battery is totally dead and hasn't charged even overnight.  I had the bulbs for neutral and oil reversed so every time you hit neutral, the oil light came on  ::)  Anyway, hopefully I can maintain some momentum...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tews19
  • I am no
« Reply #48 on: August 19, 2012, 11:54:26 AM »
Damn, glad you made a post on this. May have to try your method for the engine removal.
Offline fmctm1sw
« Reply #49 on: August 19, 2012, 07:33:10 PM »
Yeah, stolen from another member.  I got spark too!  Very weak since the battery is dead but I saw it.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
