Author Topic: (SOLVED 8.21.11) First hiway ride problems cb550  (Read 9655 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: First hiway ride problems cb550
« Reply #75 on: August 20, 2011, 10:35:21 AM »
Your talking where the needle slides into? I sprayed em real good with cleaner amd checked them in the light
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
bollingball
« Reply #76 on: August 20, 2011, 10:55:34 AM »
It looks like you got the cart before the horse. Messing with carbs before adj. valves and points. The order in which you do a 3K tuneup is very important as one adj. can and will effect another.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #77 on: August 20, 2011, 11:09:54 AM »
Where can I find that list? I m trying to do it right
Gus, Austin, MN.
bollingball
« Reply #78 on: August 20, 2011, 11:48:24 AM »
I will find it in a bit and post. I started rereading your intire thread on the first post you thought you had a hole in one of your insulator boots did you fix that is it the one with the tape on it?That tape will not hold up to the heat. My point is maybe take a deep breath reread all your post.When you find a problem like that carb insulator fix it before moving on or you may forget about it.Like TT I am not sure if you removed your emulsion tubes how many holes did you see in each one? I find the fuel bowl level check help me better than float height. Plugs looked better and it started and idles better. I think I got my measurements off (need glasses)
bollingball
« Reply #79 on: August 20, 2011, 11:59:53 AM »
1. Compression test
2. Cam chain adj.
3. Valve adj.
4. Spark plugs clean & adj.
5.Condenser
6. points
7. timing
8. Air filter
9. Carbs
This I hope is correct. Maybe TT can verify.
Sds I know your trying and I don't mean to sound critical just trying to help.
« Last Edit: August 20, 2011, 12:02:15 PM by bollingball »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #80 on: August 20, 2011, 12:04:31 PM »
Thanks
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: (SOLVED 8.21.11) First hiway ride problems cb550
« Reply #81 on: August 21, 2011, 01:41:25 PM »
All I can say right now is YeeeeeeeeHaw!!!!! This bike isn't for sale anymore!
So, I had two guys from near me come help with my CB. He just built a CB750 bobber and I had some parts he wanted. So I told him if he'd help diagnose I'd give him some of the parts. He came over and we spent 2 hours going over carbs, valves, timing, air intake, ect. Timing was off, valves were off and there was one hole that had gummed up pretty bad. When we started when it was done it popped like never before.
Took it on the hiway for thirty minutes and ran constant. no sputtering, lots of power, tons of giddy-up. We got it! CB people are great.
Gus, Austin, MN.
Offline Rgconner
« Reply #82 on: August 21, 2011, 03:31:02 PM »
glad to hear it!
They really are amazing once they are running right.
1975 CB550K aka "Grease Monkey"
Offline Tews19
  • I am no
« Reply #83 on: August 21, 2011, 06:43:12 PM »
I give you so much credit, I would have gone nutz and am going nutx with my bike... But glad you were able to pull it out... What did you have to give your neighbor for parts?
1970 Honda CB750 survivor.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #84 on: August 21, 2011, 08:58:57 PM »
A wheel and a speedo. Also 2 beers and a promise to ride later. The otherguy wanted the 77 parts 550 to start his own build. When they come back for the reat of his stuff im gonna tell him to go for it.
Gus, Austin, MN.
