Author Topic: Replacing my brake lines  (Read 5000 times)
Offline DJ_AX
Re: Replacing my brake lines
« Reply #25 on: June 28, 2012, 09:18:51 AM »
The curve on the bottom line? That'll work... as long as it's not touching the pipes or getting hung up on anything...
For my 750... PO had long forks on it. When I replaced those, of course my lower line had a lot of extra... a little more than yours shows. Worked fine.
It's the top line that's affected by your bars.
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #26 on: July 09, 2012, 08:33:21 AM »
Should be on it's way.
So I'm thinking of switching out my master cylinder for modern one. Will this work with a single disc set-up?
http://www.dimecitycycles.com/vintage-caferacer-cafe-racer-bobber-brat-chopper-custom-motorcycle-brake-parts-aluminum-universal-hydraulic-front-brake-master-cylinder-perch-lever-kit-717-602.html
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
