Poll
Does anyone know what other tanks fit the 77 CB750A? Looking one with a traditional gas cap instead of the flip top
x
0 (0%)
y
2 (100%)
Total Members Voted: 2
Author Topic: Gas Tanks for 77 CB750A  (Read 5392 times)
Offline 77 CB750A
« on: July 25, 2011, 10:01:10 AM »
Does anyone know what other tanks fit the 77 CB750A? Looking one with a traditional gas cap instead of the flip top access
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Gas Tanks for 77 CB750A
« Reply #1 on: July 25, 2011, 01:53:23 PM »
The 77-78 K model tanks will fit the 77 A but they are identical in outward appearance so that doesn't help since they also have the fuel door. The "A" tank just has the fuel gauge sender under the fuel door while the K models do not. Earlier model tanks are shorter in overall length I believe, I know someone has done a tank swap here...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Danno
« Reply #2 on: August 06, 2011, 10:30:58 PM »
the cb 550 tank will also fit the 750A and it has a flip top without the door but holds 3.7 gallons not 4.5 gallons you have to get one before 76
« Last Edit: August 20, 2011, 07:40:38 AM by Danno »
Offline jonnycakes
« Reply #3 on: August 08, 2011, 05:13:23 PM »
I going to give a 550 tank a try I think
'Matic-Fanatic
Offline jonnycakes
« Reply #4 on: August 14, 2011, 04:39:06 PM »
the cb 550 tank will also fit the 750A and it has a flip top but holds 3.7 gallons not 4.5 gallons you have to get one before 76 not the cover style
How sure are you, the tunnel is really deep and wide on the 'matic.
'Matic-Fanatic
Offline Danno
« Reply #5 on: August 20, 2011, 07:43:21 AM »
I put my 550 tank on the 76 hondamatic and the 750 tank on my 550 the tunnel is the same on the 550 as the cb750 as a matter of fact the only difference in the frames is 2 extra support rails
Offline jonnycakes
« Reply #6 on: August 25, 2011, 06:55:30 PM »
thanks
'Matic-Fanatic
Offline nixon
« Reply #7 on: November 18, 2013, 11:47:08 AM »
bumping this in case anyone has experience fitting a K0-K6 tank on 750A?  or any other tank besides the pre 76 550?
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Offline Sprocket
  • Rider of anything 2-wheeled
    • Where I work
« Reply #8 on: January 20, 2014, 10:00:24 AM »
I know it's an older thread, but I too would like to go with a "door-less" tank.  Any bolt-up options?
Jeffrey
1978 Honda CB750A (project)
2006 Honda CRF50
2006 KTM MXC450
2012 Yamaha Super Tenere
2012 Honda GoldWing
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #9 on: January 20, 2014, 11:22:46 AM »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Sprocket
    • Where I work
« Reply #10 on: January 21, 2014, 05:53:55 AM »
I am an idiot.  I was somehow reading the 550 tank had the door, but rereading the thread I see it does not.  Doh!   ;D
Jeffrey
2006 Honda CRF50
2006 KTM MXC450
2012 Honda GoldWing
Offline Bill/BentON Racing
    • BentON Racing
« Reply #11 on: January 21, 2014, 02:45:56 PM »
I put a CB350F tank on Samauto.....fit pretty well, '76 CB750A, Bill Tunnel no problem, barely touched on rt rear.
BentON Racing Website
BentON Racing Facebook
Offline nixon
« Reply #12 on: January 30, 2014, 04:03:03 PM »
Well I've got a cb750k 74 tank I'm going to put on the auto. It's not direct fit..looks about 1 cm either side , not all the way, but will need some hammering. Will post pics when get around to it.
Will need new seat for the gap created, but worth it for me
Offline Sprocket
    • Where I work
« Reply #13 on: February 03, 2014, 08:58:06 AM »
Anybody have pics of the "correct" CB550K tank needed for the CB750A?  I bought what I was told was a "mid-70's CB550K" tank from ebay and tunnel is way too narrow so I have to assume it's a '76+ tank. :-\  The filler cap is on the right side of the tank, which confuses me as some of the tanks I'm seeing advertised as pre-'76 show the filler cap in the center.  Doesn't matter to me where the cap is, but I was hoping there's some feature I can look for in pics to know for certain I'm buying the right tank. ::)
Any help with what I need to look for would be really appreciated.  I've already made one costly mistake, would prefer not to make another...  :)
Thanks!
Jeffrey
2006 Honda CRF50
2006 KTM MXC450
2012 Honda GoldWing
Offline nixon
« Reply #14 on: February 03, 2014, 01:42:44 PM »
But you like the tank right?
if you place masking tape on inside of tank, press on frame, you may find it doesn't need much to fit?
I've only spent 5 min on mine and it's already close to fitting,
Offline Sprocket
    • Where I work
« Reply #15 on: February 03, 2014, 02:37:49 PM »
Like?  Yes.  Fit isn't even close though.  To fit the 750A, the tank tunnel needs to be about 8" (20cm) wide.  The tank I have is only about 4" (10cm) wide for the most part.   :(
Jeffrey
2006 Honda CRF50
2006 KTM MXC450
2012 Honda GoldWing
