Author Topic: do I have to sync carbs changing slow jets  (Read 1336 times)
miller_87
« on: May 01, 2006, 05:21:04 PM »
Okay, here's the deal.  Ive been rejetting my carbs lately because of a Mac 4-1 exhaust I put on.  I finally got the carbs set so the engine was running pretty good accept on the low end.  I took it to the local mechanic to have it synched to see if this would help any.  He synched hte carbs, and it is running somewhat better accept on the low end.  Here's the thing, I changed the slow jets from the stock 40's to 38's, and want to put the 40's back in.  If i change those and turn out the idle screw 1.5 turns like stock, will I have to take it back in to get it synched again, or will this be okay?  My bike is a 73 cb500
Re: do I have to sync carbs changing slow jets
« Reply #1 on: May 01, 2006, 05:32:37 PM »
I know there will be those that disagree with me BUT I would would resynch. I've found changes to the low circuit,ie fuel/air screw changes etc  induces changes....period. Will it be enough to absolutely warrent resynch...probably not. I've found that every cylinder runs differently and having 4 carbs makes that point more evident. But I have the tools so it's not a big deal. Long and short...you'll be OK but I'm a perfectionist. ;)
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 01, 2006, 05:54:02 PM »
I'm with Mike on this.  If you owned a carb synch, then I'd say do it, but if you have to pay someone else to do it, then don't worry about it.
By the way, you should go out and buy a synchronizer. ;)
« Reply #3 on: May 01, 2006, 06:34:54 PM »
Gordon has more posts than me so his word IS gospel. ;) ;D
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #4 on: May 01, 2006, 07:20:00 PM »
I disagree with the others. I see no reason to re-sync merely because I changed the jets.
However.. Experience tells me. If I remove the carbs from the engine and fiddle with them. I must resysc.
Case in point. I had my carbs synced perfectly. You always know you have a good sync when you can get the engine to idle smoothly below the manufacter's recommendations. All I did was remove carbs and move the needles up one notch. Very rough idle after that. 15 minutes to resync and it's smooth as silk again.
Spend $50.00 for the sync gauges and do it yourself.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
