Author Topic: 76 cb550 wiring diagram?  (Read 23579 times)
Offline Bakeoff
« on: July 26, 2011, 09:41:24 PM »
I ended up swapping a 76 harness and fuse setup onto my 74.  The problem I'm running into is that all the wiring diagrams I find have the neutral safety circuit like my 74 had.  Maybe the harness is wrong for the 76 I had too, but any help getting the starter circuit wired up would be amazing!
Offline tango911
Re: 76 cb550 wiring diagram?
« Reply #1 on: July 27, 2011, 06:17:53 AM »
maybe a color coded one will help.
pm me if you need help ill give you my phone.  Or you can Google Talk (chat)   18atango911@gmail.com
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Bakeoff
« Reply #2 on: July 27, 2011, 06:57:49 AM »
That has the circuit I'm talking about, near the upper right corner. The parts bike I picked up didn't have that.  Thus the confusion.
Offline tango911
« Reply #3 on: July 27, 2011, 07:49:32 AM »
your talking about the Safety unit.   If you search the forum theres a way to bypass this if you are missing the unit.
Ill see if i have another unit but they are hard to find.  i know ill need one for another build.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #4 on: July 27, 2011, 07:50:59 AM »
Quote from "Honda Man"
"Find the Dark-Green/Red wire that went into the red connector that plugged into the safety module, pull it out of that connector and change the end to a male bullet, and plug it into the extra Green wire that is hanging near the rear of the battery box. Presto, it becomes a K0-K2! Just don't forget to pull in the clutch or find neutral before starting, or you'll make the DOT mad...  >:("
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Bakeoff
« Reply #5 on: July 27, 2011, 09:31:56 AM »
I have the box from my 74.  However the plug doesn't exist on the 76 harness.  Otherwise, I'd just plug it in.  There were enough shorted out wires in the 74 harness, otherwise I'd still be using that and have no issues with this circuit.
The Hondaman quote...isn't that a spade connector on the back side of the fuse panel?
I still have the neutral switch and clutch switch.  I'm just having trouble figuring out how to trigger the starter solenoid.
Offline tango911
« Reply #6 on: July 27, 2011, 10:16:35 AM »
it should be on the 76 harness.  was it cut off?
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Bakeoff
« Reply #7 on: July 27, 2011, 11:22:50 AM »
I don't see any indication of it being removed from the harness.  When I removed everything from the bike, I remember something being bolted on where the SSM is on the 74 fuse panel, but I can't for the life of me remember what it was or where it went.  I took it off so I could bolt on the SSM from the 74 before finding that harness had multiple broken wires in it.
Offline tango911
« Reply #8 on: July 27, 2011, 11:40:34 AM »
where are you located?  maybe you post some pics and/or get some local help.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Bakeoff
« Reply #9 on: July 27, 2011, 11:50:20 AM »
I'm just outside of Minneapolis.  I'll snap some pictures tonight if I don't get it figured out.
Between selling parts and your help on this, I really appreciate it Steve.  Thanks for your help!
Offline Bakeoff
« Reply #10 on: July 27, 2011, 02:15:07 PM »
Doing some more research, it looks like I might have a 550F harness...?
Offline Bakeoff
« Reply #11 on: July 28, 2011, 07:51:13 AM »
That one took care of it.  I'm back to being a happy guy!
Offline JoshuaJames
« Reply #12 on: February 29, 2012, 12:36:24 PM »
wait. is there a difference between the 550 and the 550f harness?
