Author Topic: Front Wheel Bearing Question  (Read 670 times)
Offline 736cc
« on: July 28, 2011, 03:58:45 AM »
Does front disc need to be removed when replacing front wheel bearings on CB750?
Offline Steve F
Re: Front Wheel Bearing Question
« Reply #1 on: July 28, 2011, 04:44:45 AM »
No, but it might get in the way when trying to loosen the bearing retaining nut....(question to self:  IS the nut on that side???)  Trying to visualize, not certain, but the bearing is not held captive by the disc.
Offline Johnie
« Reply #2 on: July 28, 2011, 05:35:35 AM »
The disc has to come off since the speedo gear on the right is held in place by the chrome collar which is held in place by the 6 disc bolts. Otherwise you can not remove the bearing from the right side.
« Last Edit: July 28, 2011, 05:39:15 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
