Author Topic: Signal question.. None Working.  (Read 1104 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: July 29, 2011, 03:23:41 PM »
I wired up some after market winkers today and they didn't work at all. The wiring was simple. Orange to orange, green to green on the left, light blue to light blue(aftermarket signal had a blue wire) and green to green on the right.
« Last Edit: August 03, 2011, 09:04:49 AM by robdrobd »
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
Re: Signal question..
« Reply #1 on: July 31, 2011, 09:21:15 AM »
should be orange and green on one side, light blue and green on the other....brown is always hot from the battery with the key on. green is ground
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline robdrobd
  • Who? Me?
Signal question..None Working
« Reply #2 on: August 03, 2011, 09:03:06 AM »
Well everything on my bike is working now except for the signals. I bought 4 aftermarket bullet signals from ebay. Each signal has two wires (a ground and either light blue or orange.) I bought a brand new relay and can hear it click when I try to engage the signals, but I am not getting any light at all out of the signals. The headlight works and I even hooked up the buzzer. When I engage the signal button on the hand control the buzzer works as well. I am going crazy here. I disabled the running lights because none of the new signals are dual filament. What am I missing here? All fuses seem fine and I checked the wiring harness about 50 times for loose wires and "hot" spots, nothing.
Offline robdrobd
  • Who? Me?
Re: Signal question.. None Working.
« Reply #3 on: August 03, 2011, 11:34:04 AM »
Installed new 3 prong relay. Signals still don't work and the 15a fuse blows when I turn the signals on. Could it be the cheap signals I bought from China?
Offline skamagedon
« Reply #4 on: August 03, 2011, 12:30:21 PM »
i dont know, those tiny little expert fingers...... if the old signals work, the new ones are crap...btw, are they led?
KingCustomCycles.com
« Reply #5 on: August 03, 2011, 12:32:26 PM »
Those cheapies are not case grounded, you need one wire to the blinker positive circuit and the other to a good ground.  It matters not which wire you use............
« Reply #6 on: August 03, 2011, 12:34:29 PM »
And if they are LED they will come on when wired properly, but not blink.  Test one directly to a battery to see if it is the bulb or the bike wiring.  As an alternative, you can check for continuity also using an ohm meter.
Offline robdrobd
  • Who? Me?
« Reply #7 on: August 03, 2011, 12:41:19 PM »
Lights work when wired to battery
