Author Topic: Can you use a k1 frame to restore a k4?  (Read 649 times)
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« on: August 01, 2011, 02:33:30 PM »
I have a 74 that I'd like to restore.  Got a lot of nice parts to put on it (seat, tank, sidecovers, forks, ttrees, etc.), but the frame and engine are rough.  I'm having a hard time finding a titled 74K frame.  I'm too lazy and impatient to disassemble, refinish and rebuild.  I'd like to get a frame, refinish that and just move the good parts over.
I can however get a 71K frame with title.
So the question is can everything on the K4 be used on the K1 without much trouble?  Or will there be too many little differences - like seat mounting, chain guard fitting, etc.?  What about triple trees, forks and swingarms?  All the same?
Also is there value to the K1 frame?  Should I just pick it up as an investment?  Asking price is $125 plus shipping.
Thanks,
Matt
Re: Can you use a k1 frame to restore a k4?
« Reply #1 on: August 02, 2011, 05:31:18 AM »
Don't think at $125.00 it would be an investmant that you could retire on but you should be able to move the majority of the K4 parts over.As mentioned though the K1 did use a plastic chain guard that does have a different hole spacing.When you say restore though a K4 frame would be best if you plan on dumping a lot of dollars into it,future buyers will start thinking bitsa with the 71 frame.
Offline pencap914
  • Keep it rubber side down!
« Reply #2 on: August 02, 2011, 07:42:40 AM »
I have a 1975 K5 frame and a K1 frame. The K1 frame came with a engine out of a K4.... it gets complicated quickly lol but the moral of the story is yes, you can swap most if not all the parts over from a K4 frame to a K1. From what I see is that they are identical. All the electronics are in the same spot, battery, oil tank, engine all match up. The suspension is interchangeable as well.
I plan on using the K5 frame for my build only because it has current registration and a title in my name!
Overpriced? Oh ya. Practical? Hell no. Street legal? Probably not. Time consuming? Perhaps. Worth it? Absolutely.
