Author Topic: Clutch problems.....oh boy....  (Read 13613 times)
Offline dylboss
« on: August 02, 2011, 05:59:21 PM »
I'm sorry, I know this is not the right forum for this bike, but I'm desperate for some help, please! The "other bikes" forum is so quiet all the time.
So, I just replaced the handlebars on my '72 CL350, rewired everything through the bars, etc..  Well, when I went to put the clutch cable back on the lever, I heard this "pop" come from the cover area where the clutch cable enters the housing.  It seemed like I pulled the cable too far or something.  I screwed in the adjustment screw and cable to the lever, and now the clutch doesn't work.   The lever was very easy to pull back and forth, so I knew that the rod wasn't getting any pressure applied.
So, I pulled off the cover and everything seems to be pulling back and forth normal, but the mechanism that is supposed to push in the rod seems to be slipping if the cable is adjusted too tightly.  Very strangely too, every 4th pull of the clutch, and it does that "pop", and I have to pull the cable off of the mechanism, let it seat all the way down, then push it up and reseat the cable on it.  This cycle happens over and over.
So I loosened the cable at the lower adjustment, and now the rod is getting pushed in, and the clutch feels normal now, but it is not disengaging.  I'm very confused.
Any help would be appreciated.
Thanks.
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline VTCBike750
Re: Clutch problems.....oh boy....
« Reply #1 on: August 02, 2011, 06:23:27 PM »
My first suggestion....Take it apart and see whats in there. They arent too complicated. Do you have a manual?
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline Trav-i
  • Has finally become an
« Reply #2 on: August 02, 2011, 07:36:13 PM »
Sounds like it's not adjusted properly, it sounds like it's pulling too far.  I would do a proper adjustment and go from there.  It backwards from a 750 just loosen all the adjustments bar and at the cover.  Then break the nut loose and turn the adjuster counterclockwise until you feel it touch, then back it off a quarter turn.  Then adjust the cable at the cover first (I think I took out almost all the slack there), then fine tune it at the lever.
If that doesn't work then you'll need to investigate further, including the rod and ball bearing and the cam mechanism.  They're pretty simple I'm sure you'll figure it out quickly.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline dylboss
« Reply #3 on: August 02, 2011, 07:37:50 PM »
Thanks.  I did take it apart, well the cable/push rod mechanism.  Yes, I do have a manual.  What's strange to me is that it all worked before I removed the cable from the lever.  I rode it for 150 miles prior to that.  Just not sure what I'm missing here.  The bike has less than 8k miles, so i'm sure the clutch plates and others aren't worn out.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #4 on: August 02, 2011, 08:55:44 PM »
its the same set up as the cb500s i think?with the worm/corkscrew type adjuster on the left side?has the actuation arm become sloppy on that worm thread?or is the female part slipping in the housing?have you got a photo?
Offline VTCBike750
« Reply #5 on: August 03, 2011, 06:09:55 AM »
I doubt the plates are worn out. If they are warped then it wouldnt of worked before. Definetly start with full adjustment of everything, starting at the clutch.
Great place to start!
-Adam
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: August 03, 2011, 06:29:06 AM »
Seems like the ball bearing at the lower end is missing...Larry
Offline dylboss
« Reply #7 on: August 03, 2011, 06:41:02 AM »
Yes, that's correct.  I'll try and get a photo tonight.  It seems that the female part is slipping when it is pulled to the top of the corkscrew.
The ball bearing is there.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline dylboss
« Reply #8 on: August 11, 2011, 08:26:53 AM »
So, I finally got a couple pics of this.  I've had both the cable tight and completely loose with no results.  Still cannot get the clutch to disengage, even though the lever feels normal.  Just doesn't make sense that it was working fine before I removed the cable.  Pull in the clutch at any length, and the thing just won't come out of gear.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #9 on: August 11, 2011, 01:07:06 PM »
are the ramps worn out where those three flying saucer landing gear balls ride up and cause the lateral action,is the long push rod broken?
Offline dylboss
« Reply #10 on: August 12, 2011, 11:22:49 AM »
Doesn't appear to be worn out, and the rod isn't broken.  Like I said, it feels as though the rod is being pushed in when I pull the lever, but no clutch disengage.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #11 on: August 12, 2011, 01:15:22 PM »
have you riden this bike lately?is the clutch pack just stuck together,if you try and ride the bike to break the clutch free what happens once its hot?maybe time to remove the clutch cover if riding it dosent reveal anything?
Offline camelman
  • Man... Myth... Legend
« Reply #12 on: August 12, 2011, 11:21:11 PM »
I had the same issue with my CB350 twin.  You just adjusted the clutch incorrectly and over rotated the mechanism.  If you look at the two faces of the mechanism that mate up, then you'll see what over rotating will do.
Try going through the clutch procedure again regarding setting the big screw on the side cover.  If that doesn't work, then just set the big screw a little looser so that you don't get as much movement out of the clutch mechanism.
Also, check out the hondatwins.net forum.  Sprint66 knows his stuff!
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline dylboss
« Reply #13 on: August 15, 2011, 01:14:40 PM »
Yes, you hit this on the head!  That is exactly what is happening.  I've readjusted this thing like 4 times now, and I'm still having that same issue over and over again.  I did try and adjust the side screw closer with no success.  I don't know what else to do.  I guess I'll try and post on hondatwins.net.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline dylboss
« Reply #14 on: August 15, 2011, 01:16:47 PM »
The bike has been ridden quite a lot lately, so I know it isn't anything with the clutch itself.  Was working flawlessy before I removed that blasted cable.  Now this overrotating thing is happening like camelman was explaining.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline mrrch
« Reply #15 on: August 15, 2011, 06:47:05 PM »
I remember reading about the cable pop on the twins either on DTT or the Honda twins site.
my build
