Author Topic: Mini-LED Turn Signals: Winker won't trip!!  (Read 5790 times)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« on: August 04, 2011, 08:02:23 AM »
So I am installing my turn signals with new wiring, new signals, new battery, new winker, new turn signal switch....
When I hit the switch the signals light up but don't blink.  I am using mini-led turn signals.  If I hook up the stock signals, it blinks the way it should.  So I have learned that the mini-leds are not drawing enough juice to trip the winker....hence no blinking.  I've tried three different winkers and all have the same issue.
My question is...can I put something between the winker and the light that will cuz a heavier draw on the system so the winker will trip??
Any ideas??  Anyone ever had this issue??
Thanks
Bryce
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline Patrick
Re: Mini-LED Turn Signals: Winker won't trip!!
« Reply #1 on: August 04, 2011, 08:04:18 AM »
No, you need to replace your flasher unit with a no-load electronic flasher ($8-10 Autozone). Then the LEDs will flash.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline brycegp
« Reply #2 on: August 04, 2011, 08:28:12 AM »
Patrick
I bought this one...and it doesn't work.  And effen-A, I thought it WAS electronic....BUT NOOOOOOOooo...its electro-mechanical!!  humph...NOT the same...still load dependent.
And lets say, when I asked for a fully electronic flasher, the auto zone retard was less than knowledgeable about their selection of flashers on the shelf...
http://www.autozone.com/autozone/parts/Tridon-Hazard-Warning-Flasher/_/N-9cjeg?counter=1&filterByKeyWord=flasher&fromString=search&itemIdentifier=69839_0_0_
KingCustomCycles.com
« Reply #3 on: August 04, 2011, 08:52:33 AM »
I like the clear ones so I can see all the nifty electronic gizmos inside and the absence of a bimetalic strip........
Offline brycegp
« Reply #4 on: August 04, 2011, 08:58:47 AM »
Would a fully electronic have to have 3 - Battery, ground and load - pins?  Battery + Ground to power the electronic gizmo...and the load pin goes out to the signals???
It seams to me that a two pin flasher can only be load dependent because its just a pass thru.  Or am I just retarded...?
Offline sixthwisconsin
« Reply #5 on: August 04, 2011, 11:26:43 AM »
Patrick
Get this one:
EP35
http://www.autozone.com/autozone/parts/Tridon-Hazard-Warning-Flasher/_/N-9cjeg?counter=6&itemIdentifier=6415_0_0_
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #6 on: August 04, 2011, 01:03:39 PM »
Patrick
+1
Get this one:
EP35
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline WarwickE36
« Reply #7 on: August 04, 2011, 01:03:54 PM »
You are right.  You need to run a ground to make it work.  Check power at the switch run that to the + terminal, run the other wire to the signal terminal, then make a ground wire and run it to a proper spot.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline popssss
« Reply #8 on: May 12, 2012, 09:52:32 PM »
Guys,
I tried all the tricks...with diodes, and I'm on my 4th flasher, 1 mechanical, one electro-mechanical, and two different LED flashers....NOTHING WORKS.
Someone has to have had this before...if I put one incandescent bulb in with each side, then they blink OK.
I even went to radioshack and matched the resistance of the bulb to that of a bunch of resistors, and still nothing worked.
I am ready to burn the whole thing down.
HELP...
thanks
Offline jamesb
« Reply #9 on: May 13, 2012, 08:30:16 AM »
cec industries sells the 2 prong led flasher with a ground wire attacmnet  i just bought a couple of them at the swap meet last weekend they are 10.00 dollars
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #10 on: May 13, 2012, 05:33:41 PM »
go to superbrightled.com for all that is needed to convert to LED illumination.  they have the LED blinker relays and all sorts Of useful bulbs, even a tail light bulb with plate illumination.  My CBs are all-LED now thanks to them.  I am sure my ancient and marginal charging systems are thankful.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline popssss
« Reply #11 on: May 13, 2012, 05:55:04 PM »
Thanks guys...the flashers at auto zone and other car parts stores don't work...I bought my dash LEDs from these guys, so I guess I'll get the flashers too.
My charging system will be grateful too since I have a 45/55 Headlight instead of the 35/55.
Offline aperry
« Reply #12 on: May 13, 2012, 08:27:31 PM »
+1 on the EP35 for $12.  Worked great for my mini-LED turn signals on a 750K3.
I did notice that it only worked when both the front *and* rear turn signals were plugged in.  I had originally been testing with just the front turn signals and it wasn't working.  Plugged the rears in and all of the sudden everything was perfect.  Just something to keep in mind.
Aaron
CB750K3 with F1 frame/swingarm
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
« Reply #13 on: May 13, 2012, 09:01:26 PM »
if you "bunched" them in "parallel" instead of "series" their values divided instead of adding together. Also your needing the resistance of 2 bulbs/side even if 1 bulb made it blink.
I've read the resistor solution should work, & I believe that's all that is in the gimmick adaptors sold for the same purpose.
CB750K6- survivor   CB500K2, CB550K2- projects
Offline Davez134
« Reply #14 on: March 22, 2014, 05:52:15 PM »
I had to change to LED signals because my filaments on standard bulbs kept burning out (most likely vibration from non factory mounting location) changed all 4 signals, got electronic flasher, ep35 as recommended by you guys in this post. My problem is all 4 flash, can't isolate it to one side flashing only.   1972 CB750, unmodified wiring harness.  Any recommendations?
« Last Edit: March 22, 2014, 05:59:23 PM by Davez134 »
Offline bjbuchanan
« Reply #15 on: March 22, 2014, 06:10:28 PM »
The 12$ EP35 should work. I have it on my bike, and many others have used it successfully. You should have a convenient extra ground floating around your battery box that is perfect for a seamless transition from one flasher to the other.
Davez134, you need diodes. Problem is that the low draw plays funny with these circuits. Do a diode on the orange and diode on the blue, in line. Snip and solder it in inside the HL bucket. That will make it play nicely
Offline Davez134
« Reply #16 on: March 22, 2014, 07:04:48 PM »
Thanks! After a hour or so more of searching, found a couple diagrams. Electrical is not my forte!
Offline brycegp
« Reply #17 on: March 23, 2014, 11:00:22 PM »
you have to buy an electronic winker.  the two prong mechanical thermal winker will not work with LEDs...they don't draw enough power to trip it...
Offline Davez134
« Reply #18 on: March 23, 2014, 11:14:15 PM »
Had the right relay, diodes were the problem, needed them in line with turn signal indicator light. All is right in the world now, thanks!
Offline tommy_k
« Reply #19 on: April 18, 2014, 07:57:52 PM »
Ok guys I have been following this post and I think I know what I need to do.
I bought this from superbrightleds.com:
http://www.superbrightleds.com/moreinfo/motorcycle-accessories/lf1-s-pin-universal-motorcycle-electronic-flasher/193/841/
Using these turns:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-lighting-parts-arrow-decco-style-chrome-clear-turn-signals-blinkers-26-6227.html
I am loosing my mind trying to get this to work! also specs on the diodes would help, thanks!
Offline Bodi
« Reply #20 on: April 19, 2014, 07:46:51 AM »
You do not need to add those diodes - the LEDs are diodes so putting in extra ones in series is pointless.
If you have a single signal "idiot light" (ie in the speedo), some changes are needed when converting it to an LED - but otherwise you just have to:
1) replace signal lamps with LED type (either replacement bulbs or complete units)
2) install a 3-terminal electronic flasher like the EP35.
Note the EP35 is "load sensing" and uses an alternate flash rate when less than 2 normal lamp loads are present - like with LED signals (this is supposed to warn a driver that a bulb has burnt out). I find the faster "alternate" flashing rate is better than "normal" anyway - more attention-grabbing.
