Author Topic: Jointing Compund Removal  (Read 1857 times)
supersport_CB400F
« on: May 03, 2006, 10:55:53 AM »
Has any body used a solvent to remove the excess jointing compound from the crankcases without damaging the paint, if you have what is it?
 It’s blue never sets and it sucks  :o
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Jointing Compund Removal
« Reply #1 on: May 03, 2006, 01:58:06 PM »
hi Dave, have you tried Acetone? available from a chemist shop.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #2 on: May 03, 2006, 02:30:45 PM »
Malc, that will remove the cases themselves let alone the goo ;D ;D ;D
Dave, dose this mean it's engine time ;D ;D ;D
Sam.
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #3 on: May 03, 2006, 02:57:45 PM »
beg to differ on that Sam, I have used Acetone to clean up all sorts off aluminium, however my plastic radio suffered when I knocked the bottle over  >:(
just read post again, he mentioned paint, ooops!
« Last Edit: May 03, 2006, 02:59:34 PM by malcolmgb »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #4 on: May 03, 2006, 03:08:39 PM »
 ::) ::) ::) ::) ::) ::) ::) ;D ;D ;D
supersport_CB400F
« Reply #5 on: May 03, 2006, 03:15:59 PM »
Cheers Mal I need a solvent that’s not harmful to paint I’m sure Acetone will lift it.  :o
Dave
supersport_CB400F
« Reply #6 on: May 03, 2006, 03:17:30 PM »
Sam yes! but the bloody blue goo is a bummer I used the minimum  and it still oozed
 out it’s so close to my almost perfect paint work on the top case so I have to be careful what I remove the excess with……… I’m going to spray some surplus parts at the weekend and experiment if with some stuff…. I’ll be up for a pint soon even though I’ll have a blue stripe although I’m a red……. even if I can’t find a wipe off solvent.
Dave  ;)
Offline Chris Liston
« Reply #7 on: May 03, 2006, 03:19:41 PM »
If its dry try removing it with a plastic putty knife. Shouldn't harm the paint that way.  It's worth a shot
1976 CB550F Cafe in progress
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: May 03, 2006, 04:04:46 PM »
_biffta_ ,
Based on the location of the cases, your are either a batchlor or have a v-e-r-y understanding wife.  ;)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #9 on: May 03, 2006, 04:14:44 PM »
_biffta_ ,
Bob, I was thinking along the same lines when I seen where it lay.  My wife will only let me use the basement "wreck room" ;D
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
« Reply #10 on: May 03, 2006, 04:27:08 PM »
Hey Bob and James, Over the Years I have built numerous bikes in my pad and it's a first floor flat. :o :o :o
The most I have had in there at one time was three.
In all that time, my wife has not said a word.
Saying that, I have'nt seen her for twenty years.  ;D ;D ;D ;D ;D ;D
Sam.
« Reply #11 on: May 03, 2006, 04:31:53 PM »
Sam.
You're a funny bastard Sam. Did I mention I'll be there next week?? I've use everything from MEK to brake cleaner to get stuff off. Brake cleaner or MEK gets Hylomar off etc.
« Reply #12 on: May 03, 2006, 04:43:03 PM »
Sam.
There next week ????
A house full of bikes ???
The wife's leaving you ????
Engine covered in blue goo ????
 ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #13 on: May 03, 2006, 04:52:53 PM »
Lucky guy. Take good care of her.  ;)
« Reply #14 on: May 03, 2006, 05:46:54 PM »
A solvent agression ladder.  For unknown surfaces, start at the top (least aggressive) and work toward the bottom.
 Test in an inconpicuous area first, of course.
Water
soap & water
alcohol (denatured)
Naptha (lighter fluid)
Mineral spirits
Diesel fuel
Gasoline
MEK  Methyl Ethel Ketone
Lacquer thinner
Acetone
Methyl Ethyl Chloride  (paint stripper)
Sometimes, it helps if you know what the paint composition is, as different paints have different sensitivities to solvent attack.
Catalysed paints are usually more resistant thing down the ladder than simple solids paints.
« Reply #15 on: May 03, 2006, 05:58:14 PM »
I'll tell you what there sir (Sam). I am going there and there isn't anything you can do about it ;). I'll meet you face to face someday I promise....and pints are you!
« Reply #16 on: May 03, 2006, 06:05:12 PM »
You are twittering on as if you have already had some pints, and to many of them. ;D
Are you coming over here, if so when ? 8) 8) 8)
Sam.
« Reply #17 on: May 03, 2006, 06:32:30 PM »
Sam.
Twiittering...hmmm. Not knowing what that is BUT I'm sure I've succumbed to it at one point (pint) or another. I'll be there in a year or so with me oldest boy. Christ it takes 6 months to get a Visa here now! We'll meet sir....I promise that and you know I don't fall on my word. No pints now....work in the AM  ;D
« Reply #18 on: May 03, 2006, 06:40:03 PM »
Make sure you let me know when, then I can take time off work if I am still working.
Don't go booking hotels, you can both stay with me, I only charge $300 a night ;D
Also dont book a Hire car, I don't use mine much so it's available also.
Sam.
supersport_CB400F
« Reply #19 on: May 07, 2006, 04:15:38 AM »
My freshly painted and jointing compound free cases and $18.50 pistons and barrels……get the Ale in Sam, I’ll be up for a pint soon, once I stop bouncing off the walls.
Bob put your foot down mate…I’ve never spent so much time and had so much fun in the kitchen  ;D
« Reply #20 on: May 09, 2006, 06:22:14 PM »
Nice one Dave, what did ya use to get it off ?
Sam.
