Author Topic: K2 Gas cap disassembly - Is it possible?  (Read 1314 times)
Offline VTCBike750
« on: August 06, 2011, 07:47:49 AM »
Anyone know if its possible to disassemble the inside of a 750 K2 gas cap.
Im having venting issues only when on reserve.
Basically there is Kreem inside of there from when I cleaned out the old liner. Ive been able to stick a small needle in there and get some #$%* out, but would like to take the whole thing apart and throughly clean it.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Hinomaru
Re: K2 Gas cap disassembly - Is it possible?
« Reply #1 on: August 06, 2011, 09:05:23 AM »
I take my 750K caps apart the same way forum member: Mattcb350F shows in this thread.
http://forums.sohc4.net/index.php?topic=35056.0
Scroll down for the how-to pics and use eye protection.
Offline VTCBike750
« Reply #2 on: August 06, 2011, 11:28:27 AM »
Awesome, thank you
-Adam
Offline VTCBike750
« Reply #3 on: September 24, 2011, 07:04:44 AM »
So I finally got around to taking apart the gas cap.  Been just putting up with a bike that runs lean and sputters when on reserve. Normal gas flow was fine.
Took it apart, MAN there was a ton of old Kreeme liner in there.  Probably got in there when I was shaking the tank around with acetone removing the old liner.
Should run like new now!
-Adam
Offline RustyJC
« Reply #4 on: September 24, 2011, 07:15:50 AM »
Should any K1 riders need to do this, there's a single Phillips head screw instead of the spring clips that holds the inner fuel cap assembly in place.  I also had to re-drill the vent hole after I had the fuel tank sealed when I replaced the fuel filler cap seal.
Rusty
1971 CB750K1 (original owner)
2007 BMW K1200GT
