Author Topic: plastic polish  (Read 1632 times)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
plastic polish
« on: May 03, 2006, 05:26:23 PM »
I was looking for a replacement shield for my full face helmet and can't fine any so... Have any of you used plastic polish top remove small nicks and scratches on your visor? Dose it work ? and what do you recommend?
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Gordon
  • 750K1, 550K2
Re: plastic polish
« Reply #1 on: May 03, 2006, 06:48:18 PM »
No need for special plastic polish.  Just regular old car polish works great for small scratches or haziness.  I use it all the time on my face shields and the plexiglass windshield, too.
Offline Bob Wessner
  • "Carbs Suck!"
Re: plastic polish
« Reply #2 on: May 03, 2006, 06:53:02 PM »
If the scratches are deeper, I had some turn signal lenses that were pretty bad in the sense they looked like they had kissed some pavement at one time. Before trying to locate new lenses, figured I would try to remove the scratches.. had little to lose. I started with about 400 grit paper and worked my way up to 1500 grit, then used some rubbing compound. Looked so good, I kept them. Since this is a face shield, if you try it, try it on some out of the way spot first.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: plastic polish
« Reply #3 on: May 04, 2006, 08:49:54 AM »
Most face shields have a hard outer coating which if you use a rubbing compound to remove scratches will then expose the soft core.
Also be carefull that you dont leave it with lits more tinny scratches - these will give a nice starbusrt filter effect in the rain at night, good for pepping up your photo's but no so good for riding in.
In the UK anything over 40 years old only needs insurance and Fuel.
