Author Topic: Source(s) for aluminum carb sync washers?  (Read 825 times)
Offline Ricky_Racer
« on: August 06, 2011, 10:07:05 PM »
Okay, I've checked McMaster-Carr and Fastenal, but no one seems to make aluminum washers to seal the sync screws on CB750 carbs. Close, but no cigar.
Looks to me like they're a 5mm ID x 8mm OD x .5mm thick. Honda only lists them in the gasket kit and I need a quantity of just the washers.
Anybody? Thanks in advance! RR
Offline Spanner 1
Re: Source(s) for aluminum carb sync washers?
« Reply #1 on: August 06, 2011, 10:39:46 PM »
Cant help, but I don't think any of mine have washers on them now ....... no biggie at all IMO. :)
bollingball
« Reply #2 on: August 06, 2011, 10:43:20 PM »
Rickey : seems like I read that they are the same size as the ones to shim the needle's on PD carbs maybe look for those I think Sirius has those
bollingball
« Reply #3 on: August 06, 2011, 10:46:16 PM »
Spanner has a point they are only to keep the spring from tearing the oring just file any burr off the spring IMO
Offline Ricky_Racer
« Reply #4 on: August 07, 2011, 04:10:33 PM »
Posting this update for anyone else looking for these parts... The washers you directed me to in your PM are exactly the ones I need for my sync plug screws. I've gotten the ones from Sirius and it looks like they'll work just fine.
Guess I wasn't clear, though, because I'm not looking for washers for the air bleed screws that have springs. The sync plug port plugs have no springs or o-rings, but I want to have the washers because the ports are a direct vacuum source, and they IMHO all require these washers to seal.
Thanks again to all. RR
« Last Edit: January 31, 2012, 05:47:04 PM by Ricky_Racer »
