Author Topic: Do I need to remove carbs before removing motor?  (Read 757 times)
Offline bnjnz
« on: August 07, 2011, 12:43:48 AM »
I am in the process of disassembling my bike and i am trying to see if its easier to pull the motor with or without carbs?  My concern is damaging the carbs on accident if i leave them installed.
Any thoughts?
1973 CB350f
Offline mcpuffett
Re: Do I need to remove carbs before removing motor?
« Reply #1 on: August 07, 2011, 02:07:58 AM »
Hi take the carbs off and anything else like exhaust etc will give you more room to get the motor out  ;), cheers Mick.
Offline KeithB
« Reply #2 on: August 07, 2011, 05:23:23 AM »
Remove the carbs. I took off the oil filter cover as well. On the 750, it's a tight fit.
Also helps to have some good swear words  LOL
Nanahan Man
Offline dtmmil
« Reply #3 on: August 07, 2011, 06:18:00 AM »
 I would take the carbs off. Also, oil filter, spigots if you have them, and lay the bike over on its right side on something soft, old couch cushion would work great.
Offline bnjnz
« Reply #4 on: August 07, 2011, 03:34:42 PM »
awesome, thanks for the heads up.  I was hesitant about the laying over of the bike to remove the engine.  But it seems to be a proven method on this message board.  Yeah i also noticed that the oil filter housing looked like it it would give me problems,  i will surely remove it as well.
1973 CB350f
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: August 07, 2011, 04:40:32 PM »
If this is for a 350f, you should be able to lift the motor out to the right side. I'm 64 and weigh 165 and can do it on a 400f.  It helps to take the top breather cover off.  Also, remove the cam chain adjuster bolt and nut as it can break off if it hits the frame-the end result is not fun-I know ::) :-[.   Also, remove the sprocket cover...Larry
