Author Topic: Stuttering after small tune up  (Read 659 times)
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« on: August 09, 2011, 08:31:03 AM »
Valve clearance reset, electronic ignition plate set back on the mark...
And now it sputters! @ low RPMs it sputters, and backfires/misfires on deceleration.
I'm pretty sure I didn't misalign my ignition place, but that's where I'll start looking first*.
Not after asking you guys, though, which is what I'm doing now.
What do *you* think?
*Might buy a timing light. Any ghetto ways to do this? Because I am a bit out of cash  ::)
Offline excerpt
Re: Stuttering after small tune up
« Reply #1 on: August 09, 2011, 08:46:14 AM »
ETA: It is possible to put the plate on backwards. My friend did it to my CB750. I've learned to not let him wrench on my bike.
I've used a timing light with my electronic ignition, and while doing it, I noticed that I could get it almost perfect just by listening to the bike as I moved the plate while it's running.
you can do it.
maybe take a small marker - turn the plate to the left and right to get a feel for the sound, then mark a spot to the left and to the right where you first start to hear a negative difference in the way it runs. Split the distance perfectly, and you will be damn close, if not exactly right.
That's how I did it, then I decided to just buy the stinking light, and to my surprise, I was almost exactly right.
You sure you didn't set the valves "backwards"?
« Last Edit: August 09, 2011, 11:34:21 AM by excerpt »
« Reply #2 on: August 10, 2011, 02:34:55 AM »
what ignition do you have?,some of the electronic types must be set to full advance at the correct rpm with a timing light,doing it by ear wont do,itll end up retarded,and we all know how bad that can be,how did the cbr rec/reg go?
KingCustomCycles.com
« Reply #3 on: August 10, 2011, 03:59:07 AM »
Sounds like a valve is too tight and hanging open.
    • Tin Can Customs
« Reply #4 on: August 10, 2011, 06:36:21 AM »
@ Dave: Accent. Some Germans made it. Here, the manual. I did it by the book. And the unit: good that you mention it. I had to focus on other stuff. After the 16th, I'll drop by him and let you know, k?
@ King: That might be... I'll try the electronics first. It doesn't stutter straight away, it starts doing so after riding 20+ miles.
