Author Topic: 73 cl350 Scrambler  (Read 861 times)
Offline bigragu
73 cl350 Scrambler
« on: August 09, 2011, 04:06:35 PM »
Getting a popping sound from the exhaust when coming to a stop,not as loud as back firing, idles at about 1100rpms as recommended in the book, even pressure from the pipes. Could the gas have water in it?
Offline tbpmusic
Re: 73 cl350 Scrambler
« Reply #1 on: August 09, 2011, 05:34:24 PM »
I'd suspect an exhaust leak of some sort - either at the head or at the pipe/muffler joint.
Popping on deceleration is a classic symptom.
Air gets sucked in through the leak and unspent fuel in the exhaust gets a second chance at life.......
Bill Lane
Offline bigragu
« Reply #2 on: August 09, 2011, 05:56:49 PM »
I put high temp silicon (copper color) on all the joints but maybe I missed a spot .
Thanks for your imput
