Author Topic: 400f oil seal kit  (Read 1157 times)
Offline danbar
    • dan barnett photography
400f oil seal kit
« on: August 09, 2011, 04:40:03 PM »
So I've looked around and I can't seem to find any info on where to get an oil seal kit for the bottom end.  The only thing I can find is one set on ebay out of Canada.  http://cgi.ebay.com/ebaymotors/HONDA-CB400F-CB400-F-ENGINE-OIL-SEAL-SET-ALL-YEARS-/380356094579?pt=Motorcycles_Parts_Accessories&hash=item588efd6a73
I have no idea if it matters or if there are good or bad sets out there so any info is greatly appreciated.  Anyone ever used Arusu oil seals?  Any other places to look?
I'm still not used to this marketplace.  I've been into old VW's and I'm used to having a million different places to choose from when looking for parts.  This is more like a needle in the haystack on some things.  Thanks guys.
Offline rockvegas400
Re: 400f oil seal kit
« Reply #1 on: August 09, 2011, 04:46:22 PM »
Danbar,
Don't know about the US, but 400F parts are hard to locate in Oz. I access most of my stuff from
davidsilverspares.co.uk
Justin
1975 CB400F
1988 VFR750F-J
Offline danbar
« Reply #2 on: August 09, 2011, 05:04:05 PM »
I try to avoid ordering from overseas just for the shipping cost and time.  In this case I checked already and DSS is out of stock.  Thanks for the tip though.
Offline camelman
  • Man... Myth... Legend
« Reply #4 on: August 10, 2011, 12:23:49 PM »
That is a good kit. I've used it with good results. I recommend pulling the alternator rotor before you split the cases though. It must be removed to replace the seal at that end of the crankshaft, and it is difficult to remove the rotor when the crank is not clamped inside the cases.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline danbar
« Reply #5 on: August 10, 2011, 04:33:39 PM »
Thanks guys. Ive got a gasket set and oil seals ordered up. Pistons and rings on the way too. Im looking forward to starting to re-assemble things instead of the other way around.
Offline camelman
« Reply #6 on: August 10, 2011, 05:53:14 PM »
Did you bore the cylinders?  If not, then did you have them checked for roundness?
Offline danbar
« Reply #7 on: August 10, 2011, 09:42:01 PM »
Still stock bore.  I've had them measured and checked for taper and roundness and they checked out good.  Once I get the rings and pistons I just need to take it all to the machine shop and get them honed.
Offline camelman
« Reply #8 on: August 10, 2011, 10:39:04 PM »
Good for you, that definitely makes it easier. Enjoy, and good luck assembling.
