Author Topic: Is this part of the airbox? '71 CB500  (Read 793 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 10, 2011, 07:34:39 AM »
Putting together a '71CB500 that is missing most of its nuts and bolts. Literally. Can't tell y'all how many trips I've had to make to Home Depot.....   >:(
So of course all the hardware for the airbox is missing too, but I did find this piece. Is it #10 in the diagram below? And if so, where exactly does it go? Inside lower front? Is that where the line is pointing?
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Is this part of the airbox? '71 CB500
« Reply #1 on: August 10, 2011, 08:10:48 AM »
Yep, I reckon you're right there. #15 in this pic. The pic is for 550F
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline johnrdupree
« Reply #2 on: August 10, 2011, 09:25:19 AM »
Yes, it goes inside the air filter housing and attaches it to the airbox.  If you look down in the air filter housing, right under the opening into the airbox, there are two raised lines flanking a bolt hole.  The flanged part goes between those lines and is supposed to be held still while you tighten the bolt from the outside.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: August 10, 2011, 09:41:22 AM »
So I have the screw in backwards then (in the pic above)?
Offline johnrdupree
« Reply #4 on: August 10, 2011, 09:56:47 AM »
No, the screw isn't backwards.  The flat part of the flanged thing goes against the inside wall of the air filter and the screw (bolt, actually) comes in from the outside.  Once you get the airbox and filter housing in front of you it will be straightforward.
I don't know about the 500, but on my 550, I had to assemble the air filter housing and airbox in place on the bike.  At first I assembled it on the bench and tried to cram it where it goes but it wouldn't go.  Maybe I was lacking spacial orientation skills that day but I had to take it apart and do it in place.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: August 10, 2011, 10:10:03 AM »
LOL - thanks for the tip! :) Did you do that before or after you installed the carbs?
Offline johnrdupree
« Reply #6 on: August 10, 2011, 10:19:30 AM »
Before.  With the carbs in place there isn't enough room to get the airbox in or out.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
