Author Topic: Handle Bars Swap  (Read 7648 times)
Offline INSANE REINDEER
Handle Bars Swap
« on: August 10, 2011, 07:55:14 PM »
I am finally looking to start changing some things on my bike as I have finally got it running correctly without sputtering. I want to change the handle bars to give it a little better look as well as being a little comfortable for me.I tend to want to lean forward a tad on the stock handle bars and its a little hard since they're tall. I want to get ride of the stock mirrors and put a bar end mirror on since, in my opinion, it looks better. Not a fan of the originals being so high. I have pretty much ruled out clubman because from what I've seen they seem to sit to low and have a crazy angle. (it seems like many people have them pointed at the ground) I do although like how they are on this bike.
http://www.google.com/imgres?q=cb550+clubman&um=1&hl=en&safe=off&sa=N&biw=1920&bih=941&tbm=isch&tbnid=6JNX9A6yA_KzJM:&imgrefurl=http://forums.sohc4.net/index.php%253Ftopic%253D27940.0&docid=0B3gz4mjKmCSEM&w=844&h=633&ei=BUNDTviYDdKztweF87HDCQ&zoom=1.
The only other two I have seen are the Super bike bars and the euro bars. Any others that I should look at it and what it preference for most? I can't decide on what I want. I am 6'3". (clip ons are also out of my choices)
I am going for a look like the bike in the picture. A moderate cafe look but I want to avoid changing the bike to where it can't be returned to stock.
Offline Tews19
  • I am no
Re: Handle Bars Swap
« Reply #1 on: August 10, 2011, 08:18:01 PM »
In the process literally of swapping out my bars on my 550K to superbike. Got them all on minus the throttle cables.. #$%* is irratating... Whacked myself in the face a few times with the needle nose trying to slip the last cable on with no success... You have any suggestions? Once I am able to get the cable on I will post a pic.. Maybe you will like.
1970 Honda CB750 survivor.
« Reply #2 on: August 10, 2011, 08:33:02 PM »
For the throttle cables I would just disconnect them for the carb assembly and they go on pretty easy since they will no longer be pulled/pushed by the spring. I'm guessing that is what you are talking about since you didn't really say what part was messing with you.
Offline Goldbug
« Reply #3 on: August 10, 2011, 09:44:14 PM »
I got ebay clipons. I plan to put them above the triple tree I think.
My CB650 has inverted Clubmans which is ridiculous. I am not sure if I will un-invert them or put on some Euro bars I have sitting around. Like you, I don't like the downward angle of a lot of Clubmans. Or I may pick up another set of these clip ons. They seem pretty good.
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #4 on: August 10, 2011, 09:58:13 PM »
M bar....half clubman, half drag bar
http://www.bellacorse.com/bcc028.htm
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline Goldbug
« Reply #5 on: August 10, 2011, 10:00:30 PM »
I like those bars. I just learned of them recently.
Offline Kinch
« Reply #6 on: August 10, 2011, 10:04:26 PM »
I recently changed my stock bars out for Euro bars. Was planning on keeping the stock mirrors but eventually decided on bar-ends because the stock mirrors were too close to the shoulders after changing to the Euros.
I'm 6'3 as well and love both the riding position with the Euros and the visibility with the bar-ends. Highly recommend both.
p.s. since the pic I've flipped the mirrors right-side up and visibility is better.
p.p.s those are Z1 bars, around $15 but you'll need to drill and dremel for control pegs and to run wires.
« Last Edit: August 10, 2011, 10:06:45 PM by Kinch »
1975 CB750 K5
1980 GS850L
Offline Tews19
  • I am no
« Reply #7 on: August 10, 2011, 10:04:52 PM »
superbike alll the way
« Reply #8 on: August 11, 2011, 05:21:39 AM »
I am 6`4 so give you some idea of comparison. I have a 1972 CB750 and a 1974 CB750. I have tried many different types of bars and will depend on what bars work for your arm length and what seat you are using.
1. Euro bars/stock seat - very comfy up to 75mph. Slight lean forward. Good on naked bike.
2. Superbike bars/stock seat - not so great on the highway as too much wind resistance, shoulders are rounded.
3. CB75K1 bars/stock seat - the best yet with the stock seat. Good up to 80 mph and ok after this but wind resistance becomes a factor
4. Tommaselli bars/Guilari seat - excellent combo, very comfortable on long haul and good up to 100+ mph with no wind resistance. Very hard to find these bars. With stock seat they feel completely different.
Here are a few pics:
1. Euro bars
2, Superbike bars:
Comparing superbike bars to tomaselli bars:
Good luck!
Andy
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: August 11, 2011, 09:14:22 AM »
I have the Bikemaster GP Touring bars.
Offline Bankerdanny
« Reply #10 on: August 11, 2011, 09:15:25 AM »
Another picture
Offline Tews19
  • I am no
« Reply #11 on: August 11, 2011, 10:22:25 AM »
Those look a lot like my superbike, whats the difference?
Offline Tews19
  • I am no
« Reply #14 on: August 11, 2011, 12:26:43 PM »
I do plan on changing the seat a little to have a hump in the back. Might buy one or make one but probably buy one and I will not be cutting the bike.
I think the Tomaselli bars are my favorite followed by those M Bars then the European. I have long arms. I'm guessing no modification is needed if you get 7/8 bars instead of 22mm bars since the bar is slightly smaller or is there something I should worry about?
bollingball
« Reply #15 on: August 11, 2011, 01:16:38 PM »
Do it like any bike builder does sit in the position you like measure from there to where your bars are  note difference go from there simple no brain-er ;)
Offline dhall57
« Reply #16 on: August 11, 2011, 02:14:10 PM »
These are the bars that came on my 750KO. I think they might be superbike bars, but who knows. I like them they are so much different than the factory bars that are on my 750K6. How do you handle the cable lengths with the shorter bars? do you get shorter cables or just do some magical rerouting of them.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tews19
  • I am no
« Reply #17 on: August 11, 2011, 02:31:06 PM »
I was worried bout my cable lengths as well since my bike had an extender on the bars. I rerouted the throttle cables through the upper triple treedown the frame. I had to remove the tank.  Throttle is great. May have to do something w clutch tho
« Reply #18 on: August 11, 2011, 03:14:35 PM »
I think I've decided to try the M bars since they seem to appear the height I am looking for from the picture. How much lower are they then stock though?
Offline WarwickE36
« Reply #19 on: August 11, 2011, 03:16:56 PM »
I have clubmans, the wider version, they are NOT angled towards the ground and I used stock cables, and stock length steel braided brake lines (clocked the line at the master cylinder a bit) and re-routed the cables as necessary.
« Last Edit: August 11, 2011, 03:19:55 PM by WarwickE36 »
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Tews19
  • I am no
« Reply #20 on: August 11, 2011, 03:19:53 PM »
Warick, I like your signature.... May I please see what a CB550 with style looks like?
Offline WarwickE36
« Reply #21 on: August 11, 2011, 03:21:19 PM »
LOL, Tews, recheck my post, I added another picture
wait wait wait .... here we go
VID 20110804 141033
« Last Edit: August 11, 2011, 03:26:37 PM by WarwickE36 »
2004 SV650s
Offline mrbreeze
  • Not your average
« Reply #22 on: August 11, 2011, 03:24:35 PM »
I put euros on my bike 2 or 3 years ago and haven't looked back since. Very comfy.........at least to me.
MEMBER # 257
Offline Goldbug
« Reply #23 on: August 11, 2011, 03:37:04 PM »
You appear to have them angled correctly. The point of Clubmans is they are supposed to mimic the position of clip-ons. If you pitch the "horns" down correctly you get that effect rather than the floppy bunny ear effect you get when the "horns" are more parallel to the ground. It may be that it's not possible to get the correct pitch without the wide Clubmans on certain bikes, which is why so many bikes out there look like floppy bunnies from the front.
I really dig the way the Clubmans look on your bike at the correct angle.
Offline WarwickE36
« Reply #24 on: August 11, 2011, 03:43:45 PM »
Thanks man, they are great looking, very comfortable, and made the bike feel much more stable in the corners.
I am so happy with my bars, for 45 bucks it was the single best modification I have done thus far.
2004 SV650s
