Author Topic: Fitting CB900 Rods with a .060"Spacer  (Read 1350 times)
Offline mick7504
« on: August 12, 2011, 05:55:45 AM »
Doing this has raised the question about cam chain length so I've done a mock up for reference.
For the cam sprocket to fit onto the camshaft shoulder and to leave some slack in the chain, the cylinder head needs to be surfaced down to an overall thickness of approx 71.5mm.
That is measuring from the valve cover surface to the head gasket surface.
Any more than this and the sprocket will not fit onto the camshaft.
I don't know what the stock overall thickness is, although 72.5mm is the thickest that I could find.
Everything will go together without any unneccesary force and the cam chain has about 8mm of in and out movement.
This is assembled with a stock head gasket and no gaskets on the spacer.
Here are some photos with the spacer.
« Last Edit: August 12, 2011, 06:08:05 AM by mick7504 »
If I was you
I'd be worried about me.
Offline Triffecpa
Re: Fitting CB900 Rods with a .060"Spacer
« Reply #1 on: August 12, 2011, 03:00:51 PM »
Thanks for mocking that up for the rest of us considering such a project.
Tracy
Offline mick7504
« Reply #2 on: August 13, 2011, 06:38:49 AM »
Tracy
No problems Tracy.
Good if it gives you a benchmark to work from.
There's a few variables, but no biggies with some clear thinking through it all.  8)
If I was you
« Reply #3 on: August 13, 2011, 10:46:01 AM »
Apologies for a hijack. Seems this thread may concentrate interest. I have a set of CB900 rods for sale.
