Author Topic: cb550 front wheel bearings issue  (Read 2509 times)
Offline xruss
« on: August 13, 2011, 12:06:46 PM »
I'm in the midst of swapping out the front bearings on my 76 cb550.  Got the old ones out with a blind puller.  I popped the first one in on the brake (left) side no problem by hammering it in using the old bearing.  I then slid in the spacer.  I went about the other side (speedo/right) the same way.  The inner ring spins freely on the first installed bearing.  The other is very stiff.  I'm wondering if I somehow installed it too far?  Any thoughts on this?  Can I try backing it out a bit with the puller?
1976 cb550k
Offline Lostboy Steve
Re: cb550 front wheel bearings issue
« Reply #1 on: August 13, 2011, 12:57:33 PM »
I'm pretty sure you're supposed to heat the area?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #2 on: August 13, 2011, 01:09:36 PM »
Not with a torch but a heat gun...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline xruss
« Reply #3 on: August 13, 2011, 02:13:29 PM »
Twisted, I think you're talking about getting the bearings out.  I've done that.  I'm just finding one of the new bearings to not move freely, and I'm wondering if I've somehow seated it too firmly.  Any fix?
1976 cb550k
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: August 13, 2011, 03:14:26 PM »
When you installed the new bearing, were you careful to exert force to the outer race ONLY?  Pressure or impact to the inner race is a bad thing.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline xruss
« Reply #5 on: August 13, 2011, 03:28:51 PM »
i tapped them in using the old bearing so there was even pressure all the way around.
1976 cb550k
bollingball
« Reply #6 on: August 13, 2011, 03:38:02 PM »
Even pressure good but only on the outside I think you screwed the pooch you don't use the whole (old) bearing just the outside a socket is good for this.
Offline Van-van
« Reply #7 on: October 22, 2011, 04:26:15 PM »
So, if the floating bearing is driven in too far, will that cause binding? Any fixes?
« Reply #8 on: October 22, 2011, 04:40:26 PM »
If you installed the spacer properly, you should be fine.  The bearings should require a bit of force applied to the outer race only in order to get them in.  Seat the fixed bearing first, then install the spacer, then the "floating" baring tight to the spacer.
did you notice any slop when fitting the bearings?  The should be tight, requiring a bit of force on the outer race only in order to seat them.  If the bearing can be pressed in by hand or simply dropped in, then the bearing is the wrong size or the hub is out of spec.
Sure.
Is it hard?
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #9 on: October 22, 2011, 05:23:08 PM »
+1 on heating the bearing seat. I keep the new bearing in the freezer. The seat expands, the bearing contracts and they go in easily. I have not had any problems using the old bearing to drive the new the way you did. This should create even pressure on the races and is a widely used method.
Offline Van-van
« Reply #10 on: October 23, 2011, 05:59:04 AM »
Sadface. I think I drove my bearings in too tight. I can't get them to turn by hand at all.
Offline Van-van
« Reply #11 on: October 23, 2011, 09:37:48 AM »
Ok, so the bearings are turning freely now, but I feel bumps when I spin the hub. Is this normal?
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #12 on: October 23, 2011, 09:53:07 AM »
I did this on my FZR. Bite the bullet and get a new bearing and only tap in on the outer race of the bearing. I used an old socket on mine.
I had the bumpy ride issue too until I replaced the bearing.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Van-van
« Reply #13 on: October 23, 2011, 10:00:39 AM »
Where did you get sockets that large?
Offline DavePhipps
« Reply #14 on: October 23, 2011, 10:58:56 AM »
Some funky ASE ones from father in law
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #15 on: October 23, 2011, 11:34:17 AM »
You can get singleton large sockets at most tool vendors.  Harbor Freight comes to mind.  Or you could pick up their bearing driver set for not much coin too.
Sure.
Is it hard?
Offline CoachDoc
« Reply #16 on: October 23, 2011, 11:42:34 AM »
Somebody previously posted about buying a plumbing fitting that matched the outer bearing circumference and using that to drive the bearing. Only cost a couple of bucks.
