Author Topic: 1973 CB 305/4 freshen up.. begins  (Read 1360 times)
Offline cb550ict
« on: August 13, 2011, 04:57:10 PM »
i got this from my dad hasn't ran in 20 years, should be a fun project.
Offline cb550ict
Re: 1973 CB 305/4 freshen up.. begins
« Reply #1 on: August 13, 2011, 04:59:09 PM »
did some cleaning and took off some add ons today.
« Last Edit: August 13, 2011, 05:07:49 PM by cb550ict »
Offline cb550ict
« Reply #2 on: August 13, 2011, 05:09:41 PM »
engine is free, i think i just need to clean the tank and carbs. any thoughts? should i pull the carbs and try to use starter fluid to see if she will fire?
Offline keiths
« Reply #3 on: August 13, 2011, 06:18:04 PM »
She cleaned up real nice.
I'd clean the carbs and tank. Then do a full tuneup and then see if it will fire up. She will. Mine sat for 25 years and started easily after a full tuneup.
Offline fmctm1sw
« Reply #4 on: August 14, 2011, 08:19:06 AM »
Freshen up?  I'd start that thing and ride ride the hell  out of it!
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline hoodellyhoo
  • CB350F
« Reply #5 on: August 14, 2011, 05:21:27 PM »
Take a look at your front brakes. Check for leaks. Maybe you could get away with just bleeding in new fluid but I would do a full rebuild on a system that has sat that long. Getting it running is all fun and good but remember that you need to be able to stop too.
