Author Topic: I Need Info On Any Other Rear Sprocket Working On My '72 SL350  (Read 893 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
        You see, I'm wanting to drop a few teeth from the rear sprocket on my SL350 and I need to know IF the sprockets from the CB/CL350 (or any others, for that matter)will bolt up on my SL wheel. The '72 SL350K2 carries a 42 tooth rear sprocket and the K1, uses a 40 tooth, but I haven't located a K1 rear sprocket. So, if I could find out what other sprockets would work, I could have a better chance of getting a smaller one than I have AND be able to cruise easier, with lower engine speeds and should still have enough power to plunk around off road. Thanks for any input here,  Bill  ;)
Member # 1969
Offline bill440cars
Re: I Need Info On Any Other Rear Sprocket Working On My '72 SL350
« Reply #1 on: August 18, 2011, 02:51:24 PM »
  So, I guess no one has a clue and I'll just have to get a rear sprocket for a CB/CL 350 and see what happens. Thanks anyway.
Member # 1969
Offline Danno
« Reply #2 on: October 11, 2011, 06:56:33 PM »
take measurements off the inside hub hole and of the bolt holes then go to a sprocket manufacturer and ask them if you can't find a stock one to buy they can make you one
Online grcamna2
« Reply #3 on: October 11, 2011, 07:27:32 PM »
There's a company called Sprocket Specialists that  has a rear sprocket for your bike,
they're in Ca. ...but I hear they are expensive.
