Author Topic: EVAPORUST AND WHAT IS UP WITH MY PETCOCK  (Read 2062 times)
Offline Tews19
  • I am no
« on: August 15, 2011, 06:56:50 PM »
I decided I would give it a go with the product EVAPORUST.... Here is a video of the inside of my tank... Also, is a picture of my petcock.... Why does it look like a damn straw? I will upload pictures of the after in the morning..
1970 Honda CB750 survivor.
Offline BoCoJohn
Re: EVAPORUST AND WHAT IS UP WITH MY PETCOCK
« Reply #1 on: August 15, 2011, 09:53:07 PM »
I used electrolysis to remove rust in my tank.  It worked great.  I than put a couple hand fulls of small machine screws in the tank and tumbled the tank all padded tight in my dryer.  It looked new inside when I was done.
1973 CB500
1973 CB750
1974 MR50
1975 MR50
1983 IT490
1984 XR500
1969 CT-175
Offline jodamo
« Reply #2 on: August 16, 2011, 09:17:55 AM »
There are many ways to get rid of the rust, lots of opinions, and some real experiences.  After a good deal of reading - and worrying - I used the POR-15 product.  There are some precautions but it did an excellent job.  The petcock looks like it's missing the strainer that fits over the tube.  I'd replace that first and see how much rust is getting through.  Could save you from cleaning the tank.
Offline Tews19
  • I am no
« Reply #3 on: August 16, 2011, 09:55:26 AM »
cleaned the tank, came out much better then I thought it would.. Bets part is the product can be reused... ALready took off my 550F tank to clean that.
Offline BeSeeingYou
« Reply #4 on: August 16, 2011, 10:05:39 AM »
  The "straw" is the normal fuel intake and there is another lower intake for the reserve so you can see how that works.  You are just missing the filter that fits over the whole thing like a sock.  Usually when you order a new filter the o-ring seal should be included.  Don't leave the petcock on when using any cleaning solutions.  Find a rubber stopper of the right size at the hardware store.
I would hazard a guess and say your tank does not look bad and should clean up nicely.
« Last Edit: August 16, 2011, 10:08:57 AM by srust58 »
Offline zackblack
  • Give my creation... Life!
« Reply #5 on: August 16, 2011, 10:30:24 AM »
I've used that product before and it works well - be careful of flash rusting though.  I suggest coating the inside of your tank with oil because even if it's dry the flash rust will appear.
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline Tews19
  • I am no
« Reply #6 on: August 16, 2011, 11:49:14 AM »
I rinsed it out with water several times this morning and no flash rusting.. Here is a video of the tank after Evaporust.. Not perfect but much better..
Offline BeSeeingYou
« Reply #7 on: August 16, 2011, 12:29:34 PM »
From the reports I have seen Evapo Rust is a phosphoric acid and is supposed to leave a coating that protects the steel so the water rinse is ok.  Any other acid needs to be rinsed with baking soda/ water rinse.
never used it myself but the reports are good.
Offline Zodo
« Reply #8 on: August 16, 2011, 08:06:58 PM »
I don't mean to hijack, but how do folks recommend getting oil all over the inside of the tank to avoid rusting? Should one just use fresh motor oil and slosh it around, then drain out the excess?
Offline Tews19
  • I am no
« Reply #9 on: August 16, 2011, 08:40:29 PM »
Ya no flash rusting at all. Now using it again on my other tank.. Hope the same results.. It was cool to see the towel I used to filter the product with leave rust and all this gunk in the towel..
« Reply #10 on: August 17, 2011, 05:52:53 AM »
If you are going to oil the inside of the tank I would recommend using two stroke oil.It will rinse out better than motor oil and not leave a strange sludge in there.
Offline lrutt
« Reply #11 on: August 17, 2011, 06:13:59 AM »
Hell, I run 2 stroke oil with every fill up in all my old bikes. 100:1 ratio, mixed in a 5 gal can with marine stabil. Keeps tanks from rusting, keeps petcocks working smoothly, carbs as well, keeps top ends lubed. And the new 2 stroke oils don't smoke or stink, you can't tell at that ratio. plus...what oil does pass through the engine to the exhaust, coats the pipes and will help keep them from rusting (have you ever seen a 2 stroke with pipes rusted from the inside out?).
Just my .02. from 10 years experience doing this.
