Author Topic: spray bomb questions....  (Read 15094 times)
Offline xsmooth69x
« on: August 16, 2011, 12:53:55 PM »
so can anyone enlighten me on how you spray paint lol
from what i get.....
i prep the surface (sand and then wipe down with mineral spirits)
take the primer and give it 2 light to medium coats with a few min in between.
wait a couple hours and i wet sand it to smooth it out.
so after wet sanding i wipe it down nice and clean and after that do i have to apply another coat of primer?
then after 24 hours "fully dry" i can apply the paint (but the bottle says i can also apply the topcoat within an hour or topcoat after 48?)
moving onto the color
then i apply 2-3 coats within a couple of min of each other
wait 24 and wet sand and then i clean throughly
after everything is nice and smooth do i shoot it with another coat of paint? i know the paint gets dull after sanding but will clear coat bring the color back out?
then shoot 2-3 coats of clear
let dry for 24 hours and if there is any imperfections wet sand.
if i have to wet sand do i shoot another layer of clear or can i take some clay bar or wax and will it shine again?
also how many coats is too much? i know automotive spray guns shoot out a way heavier coat of paint then spray cans. so if i want a nicer paint job do i just keep layering?
when i only shoot 2 coats the paint is really orange peeled unless i give it a really wet coat but then i run into danger of getting paint runs
any advice?
1975 CB550 (FINISHED?!?!?)
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: spray bomb questions....
« Reply #1 on: August 16, 2011, 01:12:41 PM »
Check the FAQs, Kong has an excellent write up.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: August 16, 2011, 01:14:54 PM »
XS,
I really recommend going to an auto paint store to get real auto paint mixed up (they can put it in high quality spray cans too), buy primer from them, and buy a two part clear (in a can if you need). All layers can be applied about ten minutes apart without sanding the primer as long as the temp is warm and as long as you do not use sandable primer.
Warning: use a mask and wear long sleeves. The two part clear WILL cause serious damage that landed one member on this forum in the hospital, although that is not a typical issue.
Your local paint shop will give you appropriate directions which I really suggest you follow. You'll hate yourself if your paint peals or lifts just because you tried to save time/money.
I wrote a how-to on this site in response to another paint question. Try searching for it for what I did.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Lostboy Steve
« Reply #3 on: August 16, 2011, 01:28:19 PM »
Its really a "feel" thing. It depends on type of paint, mix ration, temperature and air pressure. I sprayed my Buell and it came out ok. It was my first time spraying. I then sprayed my 1997 Honda civic with some paint I got online. It came out with a ton of orange peel. After about 10 hours of wet sanding it looks decent. I painted my brothers bike and that came out awesome. All in my garage all around the same time yet all different results. I'll post some pics later.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline xsmooth69x
« Reply #4 on: August 16, 2011, 02:37:01 PM »
im confident on the spray paint i dont need a super high quality paint just just wondering on how to spray paint well
i use a good respirator too btw dont worry im not breathing any of the stuff in
can anyone tell me after i wetsand the paint if i clear coat it will the color come back out or do i have to spray it again?
Offline cookindaddy
  • I sure love this bike!
« Reply #5 on: August 16, 2011, 02:55:37 PM »
Best to try a sample of the paint system and method you are wanting to use on some other (non-critical) part. It is hard for anyone to tell you how some "non-super high quality paint" will respond. Test it.
« Last Edit: August 16, 2011, 02:57:47 PM by cookindaddy »
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #6 on: August 16, 2011, 04:02:44 PM »
You should seriously find everything that Kong has written on the subject. He schooled me good, and although I can't wait to get anoter crack at painting with that first experience under my belt, his tips were invaluable.
Good luck.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline xsmooth69x
« Reply #7 on: August 16, 2011, 05:16:55 PM »
only thing i found was steveD about painting
anyone know kongs thread or the title so i can search it?
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: August 16, 2011, 05:54:24 PM »
Go to the search in the upper right and type kong in, you should get several results.  Or leave the box empty, click search and you'll go to advanced search, where you can search by posters...Larry
Offline chewbacca5000
  • I polish covers!
« Reply #9 on: August 16, 2011, 06:12:16 PM »
This video helped my quite a bit.  Check it out.
Airbrush Clear Coat, Buffing Out A Wicked Cool Shine, Get A Prof - Video
« Last Edit: August 16, 2011, 07:32:58 PM by chewbacca5000 »
Offline Jarhead12
« Reply #10 on: August 16, 2011, 06:17:31 PM »
http://dotheton.com/index.php?topic=10993.0
best spray right up ever. followed this and had great results.
Remember paint tanks time and good clean environment. Also remember after sanding clear coat use high quality polishing compound or buffing compound.
And the clear coat you should use is Spray Max 2k Glamour. Best stuff ever
« Reply #11 on: August 17, 2011, 10:26:25 AM »
The problem with spray bombing is that the paint doesn't achieve an extremely hard finish. You might go to buff that clear and drag the whole paint job with it.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #12 on: August 17, 2011, 10:57:58 AM »
This is the tank I sprayed for my brother did a water effect and that's a decal that was applied before the clear went on. The rest of the bike was done to match.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline xsmooth69x
« Reply #13 on: August 17, 2011, 05:16:35 PM »
this is exactly what i was looking for thank you!!!!!
Offline xsmooth69x
« Reply #14 on: August 17, 2011, 05:17:23 PM »
looks very very good! and people say spray paint isnt good
Offline Jarhead12
« Reply #15 on: August 18, 2011, 10:06:05 AM »
Hey spray paint looks great, you only notice it isn't as great if you use a magnifying glass.
Here is my black spray job.
I also repainted the emblems. Looks pretty damn good for 60$ if you ask me
Offline xsmooth69x
« Reply #16 on: August 18, 2011, 10:39:18 AM »
your bikes look awesome!!!
my spray paint job is coming out pretty well too  :)
« Reply #17 on: August 18, 2011, 11:29:24 AM »
Yeah that's actually sprayed out of a gun though... It's a lacquer and it looks even better in person.
- Sent from my iPhone using Tapatalk
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #18 on: August 18, 2011, 11:33:07 AM »
I would say do very light coats let dry and repeat lots of times if you're going to ball can it. You really way to use a urethane enamel (mixed correctly) in a decent gun. This will give the nicest most durable, gas resistant finish.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline camelman
« Reply #19 on: August 18, 2011, 01:00:59 PM »
I've had best success with cans by doing two light and smooth coats followed by a final "full" coat. Too many coats creates more points of failure and makes it more likely to chip.
I also have a local paint shop mix up very good cans. $20 per can abd completely worth it if you don't have a sprayer.
Offline Roach
« Reply #20 on: August 20, 2011, 01:55:57 AM »
problem i have run into with lower end clears are that they don't hold up to gas and just gets eaten away with even the smallest amount og gas touching it.
1978 CB550K Cafe Racer
« Reply #21 on: August 20, 2011, 07:37:35 AM »
Yep
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline VTCBike750
« Reply #22 on: December 11, 2011, 11:59:04 AM »
What about SprayMax for a final clear? Ive heard good things about it.
Can you get rattle cans of metallic flake? Perusing House of Kolor's ebay listings and none of the flakes are available in a can.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline 78whiteorbs
« Reply #23 on: December 11, 2011, 01:39:31 PM »
check my thread here- http://forums.sohc4.net/index.php?topic=98350.0
you can order this in just about any paint code of any modern vehicle. Pictures are of a "metallic" orange that has mica flakes in it and looks awesome in the sun. Larger flakes I would believe you could only do with  a serperate stage in a  "flake gun" .
Offline VTCBike750
« Reply #24 on: December 11, 2011, 02:49:59 PM »
very cool. Ill have to check it out.  Id still have to get the clear coat to go over everything. to protect the stripes.  What would you use as a primer under Spray Max 2K?
-Adam
