Author Topic: discolored pipe chrome  (Read 1045 times)
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
« on: August 16, 2011, 10:27:09 PM »
CB750K6 completely stock.
#1 pipe was a little gold from heat when I got it from the P.O. (2-4 are bright chrome)
He claimed the problem (carb) had been rectified by the Honda dealer.
I think it's still questionable/getting worse. I need to review the factory service manual.
Could I make sure it's not lean without removing carbs, via the float bowl- check jet(s), emulsion tube, etc? or remove tank- check needles? :-\ Thanks :)
CB750K6- survivor   CB500K2, CB550K2- projects
Re: discolored pipe chrome
« Reply #1 on: August 17, 2011, 05:03:57 AM »
Does the spark plug show the signs of running lean.Put a new one in and check it after a bit. Also touch all 4 header pipes with a wet rag and observe the 'sizzle' and see if #1 is more pronounced or check them all with one of those cool thermal gadgets. Did the PO ever say what the pro's did to rectify it ?
  • SEE YOUR AD HERE!
« Reply #2 on: August 18, 2011, 10:23:06 PM »
I checked the plugs when acquired, but should check again.
Thanks for the wet rag tip, I don't have the thermal gadget.
No, the PO just said the local Honda service dept had "addressed" it.
KingCustomCycles.com
« Reply #3 on: August 19, 2011, 03:10:42 AM »
Burnt valves will do that, as the fuel excapes, it ignites and heats up the pipe.
