Author Topic: oil passage plug 82 cb650  (Read 1129 times)
Offline OLDHEAD
« on: August 17, 2011, 04:04:25 PM »
What is the function of the oil passage plug?
a huh
Offline scunny
  • don't call me expert
Re: oil passage plug 82 cb650
« Reply #1 on: August 17, 2011, 11:23:58 PM »
if it's the 2 in the lower crankcase half, I believe they were to do with the case manufacture and serve no normal service. mind you I'm just back from the pub so what do I know. might be a spot you can use for external oil lines ?
if it's the restrictors between block and head, they are to keep your cam from seizing from lack of oil.
« Last Edit: August 17, 2011, 11:26:45 PM by scunny »
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline OLDHEAD
« Reply #2 on: August 20, 2011, 07:50:51 AM »
its the plug on the LH lower crancase under the alternator , so! since i cannot get it to stop from popping out.you thing i could fill the recess in the alternator cover with jb weld so it holds it in place beter? i was concerned that the plug might of bein an  oil release safety against high pressure inside the crankases. i mean why have something that does nothing?
a huh
Offline OLDHEAD
« Reply #3 on: August 20, 2011, 01:27:08 PM »
Can I use any type o ring in there or oem only will work
a huh
Offline OLDHEAD
« Reply #4 on: August 21, 2011, 09:51:10 PM »
buna didnt work so i lltry viton
a huh
Offline OLDHEAD
« Reply #5 on: August 22, 2011, 01:36:55 PM »
Ever feel like you re talking to yourself? Anyway viton lasted longer till I took it on the highway then it leaked interestingly when I got back to the garage I checked the temperatures at the exhaust colars and I got 350 on 4 &3 300 on 2 and 222 on 1 I wonder if I got an oil block and is popping the plug on pressure increase
a huh
