Author Topic: McMaster carr  (Read 1566 times)
Offline bert96
  • past ride
McMaster carr
« on: August 19, 2011, 10:26:47 AM »
 Anyone know a place that sell parts similar to McMaster carr?
 I can't buy from theme....they don't ship to Canada because of '' the complexcity of U.S
 Export regulations''  :(
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline rbmgf7
  • 2>4
Re: McMaster carr
« Reply #1 on: August 19, 2011, 11:09:01 AM »
What part's exaclty? I use them mostly for fasteners and small amounts of structural steel. If you want fasteners, Fastenal is about your next best bet.
Offline bert96
  • past ride
Re: McMaster carr
« Reply #2 on: August 19, 2011, 06:02:41 PM »
 I need small aluminum rod,clevis rod end amd clevis pin.
Offline Tanqueracer
  • "You can't step into Victory Lane with your foot on the Brake"
  • www.yanquetanque.com
    • Yanque Tanque racing
Re: McMaster carr
« Reply #3 on: August 20, 2011, 04:40:29 PM »
Try MSC Industrial. Don't know about shipping to Canada, but they have everything MCMCarr does.
"The older I get the faster I was"!
Offline bert96
  • past ride
Re: McMaster carr
« Reply #4 on: August 20, 2011, 04:47:44 PM »
 I will,
Thanks
Bert
Offline rbmgf7
  • 2>4
Re: McMaster carr
« Reply #5 on: August 20, 2011, 05:16:22 PM »
Sounds like rearset linkages?
Try between Guzzino and Wick Aircraft. Guzzino has aluminum clevis in metric while Wicks is steel in standard.
Offline bert96
  • past ride
Re: McMaster carr
« Reply #6 on: August 21, 2011, 05:49:01 AM »
 No,it's not rear set linkage,as i said in another thread,i want to do a brake rod à la Joker machine(i have found my M6 X1MM stainless rod by the way,thanks to inoxgrp)
Bert
Re: McMaster carr
« Reply #7 on: August 21, 2011, 12:12:10 PM »
 6mm is way too small for a brake rod..
 I used to use 3/8 or 5/16 male rod ends, then thread tubing, to put it together, think it was 1/4 heavy wall tubing.
 It is nice to be able to TURN the brake plate 90 degrees OUT OF THE WAY, when removing wheel.. just leave locknits loose.
 Rod ends are available at many bearing supliers, make sure you get good ones... for the rod or tube.. find a friendly machinist to  do it for you..
Offline bert96
  • past ride
Re: McMaster carr
« Reply #8 on: August 21, 2011, 02:47:44 PM »
Re: McMaster carr
« Reply #9 on: August 21, 2011, 08:29:22 PM »
 I thought you meant brake torque arm! Did not know there is a shortage of stock. brake  rods!
 I will be making a batch of knurled adjusters soon
Offline bert96
  • past ride
Re: McMaster carr
« Reply #10 on: August 21, 2011, 11:19:59 PM »
 Let me know,i would like to have one !
Bert
