Author Topic: charging prob.....  (Read 829 times)
Offline brcree
  • A breeze on the knees anytime!
charging prob.....
« on: August 20, 2011, 11:39:09 am »
I have a 750 k that has a chrging problem....not charging. I've checked the voltage reg. and silicon unit, both seem ok. When I put a meter on the batt. and rev. bike up...the reading stays the same, around 12 volts. Any help would be great. ???
In God We Trust......
bollingball
Re: charging prob.....
« Reply #1 on: August 20, 2011, 12:20:14 pm »
Offline brcree
« Reply #2 on: August 20, 2011, 12:43:17 pm »
Thanks Bollingball....new to this forum...but not bikes!
bollingball
« Reply #3 on: August 20, 2011, 01:36:36 pm »
After reading drop back with any concerns :) When I can't sleep I can read FAQ and Tip & Tricks all night good stuff.
Offline brcree
« Reply #4 on: August 22, 2011, 12:07:23 pm »
Thanks man...well I looked it over...made sure I reved up to 5000 rpm...still meter reads around 12 v. Took volt reg apart and did the adj. per shop Manuel, not clymers. Still the same. Need to check the ceramic part next...the part that is bolted to the volt reg. frame. If I need a new volt reg...can you give any ideas where to find? I've looked at DGY and other places but none show the reg. :-\
« Reply #5 on: August 22, 2011, 12:19:36 pm »
If you have an ohm meter and know how to use it. Check the resistance across the white and green wire  at the Vreg (disconnected)
Next disconnect the rectifier and check the resistance of the Yellow stator wires, to each other and to Frame ground.
I don't know what type of voltmeter you have (there are hundreds of thousands of them and almost as many designs).
But, with the key switch on as well as lighting, measure the Black wire at the Vreg to see if it is different from the actual battery voltage; S/B within .5 V.
Do the same measurement at the Rectifier plug across the Red/Wht and Green.
You could also check the six rectifier diodes to verify they conduct in one direction only.  The right meter and scale selection is quite important here, so refer to your meter's owner's manual.
Offline brcree
« Reply #6 on: August 22, 2011, 12:25:30 pm »
Tah Two........ ;)
