Author Topic: Cylinders not resting against case?? - was the tensioner  (Read 882 times)
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« on: August 21, 2011, 07:31:30 PM »
So I put my cylinders on and I cant seem to get them to sit down. I can get about 1/8 inch gap, any further and only one side will go down at a time, like something is holding it up. Cant think of what could hold it, except studs. Havent put much force, and I'm pretty sure the head with some torque would push it right down. Im not to worried just thought it should rest against the case.    Any thoughts?
oops CB750
« Last Edit: August 22, 2011, 08:14:04 PM by millerza »
Re: Cylinders not resting against case??
« Reply #1 on: August 21, 2011, 07:42:37 PM »
Assuming CB750?
2 things. Usually.
The dowels are too long or aren't seating well.
The cam chain tensioner slider has a removable bar in it that needs to seat well.
Do not force it with the nuts drawing it down. It should sit flat and flush with nothing more than some rubber mallet taps.
« Last Edit: August 21, 2011, 07:59:47 PM by MCRider »
Offline the technological J
  • deliciouso!
« Reply #2 on: August 21, 2011, 07:57:29 PM »
def maybe the dowels but my money is on bottom of the cam chain slider.... lift it up an inch or 2 without having to compress the rings and see if you can figure it out
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Trav-i
  • Has finally become an
« Reply #3 on: August 21, 2011, 07:59:19 PM »
+1 on the cam chain guide pin.
Forum member #9962
1992 GL1500 Interstate
« Reply #4 on: August 21, 2011, 08:01:44 PM »
yeah, I just did mine. First double checked the dowels before dropping the cyinders. But I did hang up on the slider. Luckily did not rip the base gasket lifting the cylinder enough to seat the pin in the slider into the cases.
Offline millerza
  • Zach Miller
« Reply #5 on: August 21, 2011, 08:06:59 PM »
thanks- turns out it was the tensioner, I appreciate the help. I had the plastic black things upside down. Chaulk this one up to impatience.
« Last Edit: August 22, 2011, 08:16:28 PM by millerza »
