Author Topic: A CR750 Build  (Read 68251 times)
Offline H2Eric
Re: A CR750 Build
« Reply #25 on: September 12, 2011, 04:15:11 AM »
Hi Régis
The tanks were made by Peter Kyte (Custom Tanks and Designs), Pershore, Worcestershire, England.  0044 (0) 1386 554136. He was significantly cheaper than anyone else, but be warned there is usually a long waiting list for his services. It was over a year in my case from placing the order to receiving the parts. However, he is honest enough to tell you approximately how long you will have to wait so you know where you stand and make the choice to either wait or take your custom elsewhere. He tells me that all the info he has on the design of the CR750 fuel tank and oil tank came from Kurt Liebmann.
As for the headstock, my frame remains standard in that respect. There are a couple of pictures of the in the Daytona CR thread as supplied by Ben, I'm sure he will not mind me repeating them here so you can see the difference between the standard frame and the race frame.
The standard frame - first pic below
and the race frame - second pic below
Note how the headstock on the race frame is much lower (by approx 25mm - KOS may confirm) as well as the positioning of the down tubes. The top spar is also at a shallower angle to the top tubes. Whether it is possible to convert a standard road bike frame to this specification I know not, but perchance there are some welding wizards out there who can. I would imagine that the whole of the original headstock would have to be removed and a new one fitted. Some of the chopper boys do that sort of thing so perchance it's possible, but would you trust it? It might be wise though to start from scratch and build a new frame. Anyone got any drawings? or better still an original frame to copy from? You will have read elsewhere in this thread that the race frame pictured above was sold to a gentleman in Italy. Well dear reader I have it on good authority that the buyer is having a copy made. It will be great to see how that project turns out.
Cheers
Eric
« Last Edit: January 19, 2023, 06:31:25 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline lordmoonpie
    • Moonpie
Re: A CR750 Build
« Reply #26 on: September 12, 2011, 09:36:15 AM »
I'd heard Peter Keyte has retired Eric - not taking in any more work. Do you know if that's the case?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline H2Eric
Re: A CR750 Build
« Reply #27 on: September 12, 2011, 01:44:15 PM »
Hi Simon
No I wasn't aware that he may have retired.  Good job I got my tanks when I did.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline RegDeg
    • degrave-motocycles.com
Re: A CR750 Build
« Reply #28 on: September 12, 2011, 04:29:55 PM »
Thanks Eric for these informations.
I'm buying parts to make my own CR750 streetlegal (as if HRC would make a replica for the road in the 60's...no fairing but the same engine, same mod's of the frame, with magnesium menani drum 250mm) since 2 years and it is the 1st time I see a fuel tank as I would have.
I will try to contact this week Peter to know if he is retired or not. Unfortunately, by phone my english is poor, like every french guy I think!
Your tank is very similar with the one I have mounted on my CR450 I have built few years ago
(I will post an image when I could!)
I hope really he isn't retired.... I were very sad...
For the mods of the frame, it is a real work. It is feasible but I think the need of 2 frames. I do not see how to do to extract the headstock without match tubes or the headstock....
Another part I think modified is the stamped part at the rear of the top spar, wich control the angulation of this. More pictures of this frame were be great!
As you supposed, building a new frame is maybe better.... The original tubes are like chewing-gum as I read!
What do you think about megaphones? Wich one you will install on it? I've seen at Coupes Moto Legende the "Mercier meg" : seems great with, for the inf ones, the double curvature to match with originals.
I have nothing against him, absolutely nothing but they seems to me really too expensive for the work :more than 2000€! (but I think always about them....)
A last question: Where did you find your tachometer and your magnesium bottom legs?
Thanks, great job, I spit....
Original CB450 K5 and its racer
Dream 50
SS50E and Z
BMW R69S
Ducati 888 SP4
Royal Enfield 700 Interceptor
CR 750 cafe-racer from 60's (project)
Offline H2Eric
Re: A CR750 Build
« Reply #29 on: September 15, 2011, 02:21:42 PM »
A few more pics of the cross over gear change.
The left side
The right side
and a close up
The bearing is bolted to the engine plate and tucks neatly into the frame.
Eric
« Last Edit: January 19, 2023, 06:35:32 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline brandEn
Re: A CR750 Build
« Reply #30 on: September 15, 2011, 02:39:45 PM »
Wow that looks awesome. I can just picture myself hauling ass and hitting the rear brake instead of the shifter!
  • Moderator
Re: A CR750 Build
« Reply #31 on: September 15, 2011, 03:06:39 PM »
It's been done before, ask me how I know?  Bloody British bikes.  ;D ;D ;D ;D ;D ;D ;D
Sam. ;D
Offline cobra
Re: A CR750 Build
« Reply #32 on: September 16, 2011, 11:28:50 AM »
now where can i get a bearing housing like that?
Offline H2Eric
Re: A CR750 Build
« Reply #33 on: March 22, 2012, 06:58:55 AM »
Hi folks
It's time to revive this particular thread. It's not dead, but only sleepth over the winter. Anyway with all the excitement of the Russ Collins AT&SF revival and the temperature in my garage or more to the point the lack of it, the CR project has taken a bit of a back seat. New goodies have arrived in the form of;
a replica oil cooler;
a JMR Stage 4 cylinder head
Nice man that Mr. Reick and a spiffing job as well.
One of the major jobs over the winter has been getting the oil tank in just the right place to give sufficient Clarence with the fuel tap when its in the open position. I think I had 4 attempts at all the brackets before I was happy with it. Other jobs have included the rear brake cable and its attachment to the frame on the left side. Paul McGhie kindly provided some photographs to work from.
Coming back to the oil tank for a moment, does anyone know of a source for the braided oil lines that Honda originally used as I need some to connect the up the oil cooler, oil tank and engine ?
I have all the necessary end fittings, I just need the braided pipe to go in between.
Another distraction over the winter has been a CB750 in the form of a K3 complete with JMR 1000cc cylinder block. I say K3 as that is the model of the frame whereas in fact it has bits from most of the other models in its make up. Perhaps it should be referred to as a K9 (canine) as it's somewhat of a mongrel.  ;D ;D ;D
Spring is here, the sun is out, things to do
Cheers for now
Eric
« Last Edit: January 19, 2023, 06:43:58 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
  • Moderator
Re: A CR750 Build
« Reply #34 on: March 22, 2012, 07:12:40 AM »
Quote Eric.
Cheers for now
Eric
When Spring comes around, most mens fancy turns to LOVE ::)
Sam. ;D
Offline H2Eric
Re: A CR750 Build
« Reply #35 on: March 22, 2012, 01:11:26 PM »
Sam. ;D
Yeah, the LOVE of bikes
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
  • Moderator
Re: A CR750 Build
« Reply #36 on: March 22, 2012, 01:16:42 PM »
That's my man Eric, A REAL MAN. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Priorities in the right order. ::)
Sam. ;)
Offline lordmoonpie
    • Moonpie
Re: A CR750 Build
« Reply #37 on: March 23, 2012, 12:59:50 AM »
Braided oil lines - hey Eric, do you want the black cloth wrapped lines of old? In which case Mead Speed sell these normally with the cooler but you shoudl be able to convince them to sell a bit of oil line to you. Failing that try Autohoses in Stoke on trent. That'll get you the line and then you can send this to Earl's at Silverstone to getthe fittings swaged onto it....
Looking good...!
1994 Ducati 888 SP5
Offline H2Eric
Re: A CR750 Build
« Reply #38 on: March 23, 2012, 09:51:53 PM »
What ho Simon
That's what I need, the old cloth wrapped stuff. Thanks for the tip, I'm on the case.
Tootle pip
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Re: A CR750 Build
« Reply #39 on: March 24, 2012, 08:34:53 PM »
The K3 looks fantastic Eric. Kind of the sleeper look......until you twist that thing! ;D ;D ;D You'll have some fun with that. ;) Pics of the head came out great too...thanks!
« Last Edit: March 24, 2012, 08:36:24 PM by MRieck »
Offline brandEn
Re: A CR750 Build
« Reply #40 on: April 15, 2012, 04:51:12 PM »
subscribed
Offline RickB
    • Pop Magazine
Re: A CR750 Build
« Reply #41 on: December 19, 2012, 07:10:46 PM »
Eric, any updates mate?
Offline H2Eric
Re: A CR750 Build
« Reply #42 on: December 20, 2012, 02:40:58 PM »
Oh yes. Just need to get the bike outside when the gods decide to desist with the rain to take some piccies.
Watch this space.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
  • Moderator
Re: A CR750 Build
« Reply #43 on: December 20, 2012, 04:27:12 PM »
Don't hold ya breath Rick, It's been raining none stop since July and the F...in place is under water. :(
Sam. ;)
Offline H2Eric
Re: A CR750 Build
« Reply #44 on: December 22, 2012, 09:48:49 AM »
I've not been outside for fear of drowning so here are a few pics taken indoors to bring you up to date with progress.
Oil cooler now fitted along with the connecting pipes. New oil pressure gauge with the correct mount.
more to follow
« Last Edit: January 19, 2023, 06:50:40 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline H2Eric
Re: A CR750 Build
« Reply #45 on: December 22, 2012, 10:00:14 AM »
The engine has been out of the frame and the Mike Rieck cylinder head fiited, but before it went on the exhaust ports were opened up to take the exhaust pipes. Yes folks we have exhausts at long last.
I'm still waiting waiting for a magneto to fit behind the M3 Racing cover, but meanwhile I though I might try one of those self generating ignition systems from Electrex World.
Update 19th January 2023
An original magneto has been impossible to find, so the Electrex World system is still in operation and it works very well.
« Last Edit: January 19, 2023, 06:58:59 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline H2Eric
Re: A CR750 Build
« Reply #46 on: December 22, 2012, 10:14:42 AM »
More piccies including the shaving of the fins in various stages
and while I've been waiting for parts (as usual) K9 is now just about complete apart from the wiring.
If anybody is interested the exhaust is one of Steve Carpenter's efforts.
Cheers
Eric
« Last Edit: January 19, 2023, 07:07:09 AM by H2Eric »
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Re: A CR750 Build
« Reply #47 on: December 22, 2012, 10:48:58 AM »
Great work all around Eric. Beautiful.
Re: A CR750 Build
« Reply #48 on: December 22, 2012, 12:35:41 PM »
Amen!
Re: A CR750 Build
« Reply #49 on: December 22, 2012, 02:54:20 PM »
Those Billet blocks look plain mean.... 8)  Very nice.... ;D
