Were all messed-up here, folks. Poster we do not need 'key turned on'... were not testing for voltage here. No key on, por favor. We need to know if the field coil is good, which is tested thus;
The regulator has 3 wires to it. The white wire and the green wire go to the field coil. Disconnect them from the reg. and put your meter leads to white and green ( +,- doesn't matter to which lead ). Now, click your meter to it's lowest Ohms scale, (you report 200 ohms is the lowest 'click', we do not want the diode test setting, so stay @ 200 ohms scale ). What's the reading ?
