Author Topic: Tapered Bearings - Shim Question  (Read 710 times)
Offline Mandic
« on: August 24, 2011, 11:17:32 AM »
So in the next few days I will be overhauling my neck and installing a new fork with tapered bearings from All Balls.  My concern is the shims that come with this setup.  How do I determine the shim thickness if the bearings are not present?  I have an entire fork I am installing that came with no bearings.  Upon disassembly of my current fork setup the bearings of course fell to pieces.  Where exactly am I to take measurements?  And what if I just cannot?  Will it matter from fork to fork?  They are both 77-78 750F forks just swapping from one to the other.
Sorry I asked a lot here, I just haven't found this situation from the little bit of searching I did.  Just reference to "measuring the bearing stack."
77 CB750F - Cafe/Daily Rider
Offline Silverback
Re: Tapered Bearings - Shim Question
« Reply #1 on: August 24, 2011, 11:27:19 AM »
I have never used the thick shim on any SOHC bikes. More specifically, the thin shim is what was required for my 78F.
There is a thread that shows how to measure the stack. Maybe in FAQs!?
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline CycleRanger
  • No comment about being an
« Reply #2 on: August 24, 2011, 11:48:11 AM »
I used the "thin" shim with my 750 and I believe everyone else has as well.
Offline Trav-i
  • Has finally become an
« Reply #3 on: August 24, 2011, 01:09:01 PM »
+3 on only using the thin shim.  I have done 2 bikes and never used the thick shim.
Forum member #9962
1992 GL1500 Interstate
