Author Topic: Anyone need any 76 parts?  (Read 4319 times)
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« on: August 25, 2011, 07:36:02 AM »
Got a hondamatic yesterday for a small song, it's partially in boxes, but it's a 76, and I have literally every part. The only thing rusted out is the muffler (the 4-1 muffler, the header is in very good shape). Figured I'd post here instead of the classifieds, as it'll get swamped amidst the non-hondamatic related stuff =P.  I can take pictures of anything, and would be happy to ship anywhere.
Cheers!
Sam: If this was not okay, I'd very much understand if I found this moved to the parts section!
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Re: Anyone need any 76 parts?
« Reply #1 on: August 29, 2011, 06:22:18 PM »
'75 CB750 - Racer
'69 CB350 - Racer
Offline Chuck Hahn
« Reply #2 on: September 06, 2011, 04:34:44 PM »
I have the 76 750A and i need the rear chrome grabrail thing and rear turn signals with the mounting hardware...  Message me if you can help, thanks...Chuck
Offline Fran Fitzpatrick
« Reply #3 on: September 08, 2011, 04:47:25 PM »
I have a CB750A that needs a fuel petcock my current one has sat for 30 years and leaks.  Does you petcock still hold fuel?
« Reply #4 on: September 08, 2011, 05:11:22 PM »
Sent a message to ya, Fran.
Chuck:
The grab bar on a 76 is a black plastic thing, unless I'm very mistaken. It goes on the seat and loops around behind the seat:
I do have the black plastic one from this 76.
Cheers!
'75 CB750 - Racer
'69 CB350 - Racer
Offline jonnycakes
« Reply #5 on: September 08, 2011, 07:04:32 PM »
I need the little chrome cover that goes on the torque converter........not all bent up like mine. shipped to 33712
'Matic-Fanatic
« Reply #6 on: September 08, 2011, 07:14:58 PM »
That cover is a little bent up on mine as well, PO dropped the bike, bending that cover, the pts cover and the tank. At the same time, I'm also looking to keep the engine, or part with it as one large unit =P
'75 CB750 - Racer
'69 CB350 - Racer
Offline H2Eric
« Reply #7 on: September 20, 2011, 05:05:45 AM »
I'd be interesred in the front brake caliper and mount if it's available. Shipped to the UK.
Thanks
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
« Reply #8 on: September 22, 2011, 04:28:17 PM »
Replied, enjoy your caliper  ;D
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #9 on: September 22, 2011, 04:31:08 PM »
#20-0105
#20-0106
These adapters from http://www.partsnmore.com should work, and were the ones we discussed by phone!
If you're looking for OEM, this is from my local honda store. Was kicking around and asked them if they can look it up for me today  ;D
16950-405-831      1978    CB550K
16950-405-831       1978   CB750A
16950-405-831      1978   CB750K
16950-410-015       1978   CB750F
16950-393-015      1977   CB750A
16950-410-015      1977   CB750K
16950-410-015       1977   CB750F
16950-393-015      1976   CB750A
16950-341-671      1976   CB750K
16950-341-671      1976   CB750F
Those are the part numbers for full petcock assemblies....so basically look for a 78K or 78K (CB550) petcock as they'll be the same as well.
« Last Edit: September 22, 2011, 04:43:49 PM by MidnightLamp »
'75 CB750 - Racer
'69 CB350 - Racer
Offline RuffTuffGuy
  • "Go With the Flow"
« Reply #10 on: September 22, 2011, 05:11:00 PM »
I could use the headlight ears and all turn signals. Mine are all bent up. Also how are the airbox to carb boots? Shipped to 15010?
« Last Edit: September 22, 2011, 05:16:20 PM by RuffTuffGuy »
Guy is my name...not Gary or Guss
Offline tutnai
« Reply #11 on: October 21, 2011, 07:38:21 AM »
Hi!
I'm a bit late to this post, but my '76 gives me a heap of electrical problems. Would love a chance at switches, regulator, recitifier etc.
Thanks!
« Reply #12 on: October 25, 2011, 10:46:45 AM »
Didn't see this till now! I'll dig through and see what's there!
'75 CB750 - Racer
'69 CB350 - Racer
Offline Old Scrambler
« Reply #13 on: November 08, 2011, 07:11:02 PM »
Do you have a rear fender?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #14 on: November 09, 2011, 06:58:56 PM »
Messaged back!
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #15 on: November 24, 2011, 12:06:14 AM »
What kind of shape are the carburetor manifolds in?  I need the set that go between the cylinders and the carburetors.
« Reply #16 on: December 07, 2011, 11:19:12 AM »
Are you still parting out your CB750A.  I need a set of carburetor insulators / manifolds.
« Reply #17 on: December 07, 2011, 02:05:10 PM »
is the back rim 18" aluminum?...if so how much to Kalamazoo, MI. 49007?
« Reply #18 on: December 09, 2011, 03:58:47 PM »
Been away from the forums a bit for my undergraduate finals, so I only got to this now, sorry chaps!
Fran: Check your email. I'd suggest restoring over using questionably old used manifolds. I have the ones you need, but they're not in amazing shape, like most honda manifolds of this age. Try searching for the wintergreen trick on here, and combine that with some RTV to seal the leaks!
Sean: The rear rim would be 17" for these models. The auto came with the same rim as the later K's and the GL-1000, and was a 17" DID alloy. For larger items like that, I'd check your local scrapyard for a GL, as the rim will come very cheap.
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #19 on: December 09, 2011, 06:10:11 PM »
thanks, I got a 17" gl rim...was hoping for an 18"
Offline rbgltd
« Reply #20 on: January 28, 2012, 02:59:42 PM »
i need start button the whole right hand control would do(start button kill switch etc...)
« Last Edit: January 28, 2012, 03:01:40 PM by rbgltd »
Offline messeduptriple
« Reply #21 on: January 28, 2012, 03:04:37 PM »
U have side covers??
Sent from my PC36100 using Tapatalk
Offline rbgltd
« Reply #22 on: April 09, 2012, 05:59:25 AM »
i need a start switch / right hand control for my 1976 750A. also i am looking for a hi/lo seat (similiar to the 1977 750A seat)
Offline 1974cb550k
« Reply #23 on: May 20, 2012, 01:09:10 PM »
speedo, tank seat. Thanks
