Author Topic: 78 750 f2 headlight  (Read 1078 times)
NOLAN78F
78 750 f2 headlight
« on: May 06, 2006, 05:47:11 PM »
I am the proud owner of a '78 750F2.   I just traded my dohc custom for my new bike.  The CB 750F2 had a windjammer, front wind shield, and faring.  I want to restore the bike to original condition, but after removing the windjammer I now need front directionals and headlight assembly.   I am wondering if I can use older headlight assemblies off older k-models. I would really appreciate any feedback and pictures  of how the headlight assemblies mount to the forks.
upperlake04
Re: 78 750 f2 headlight
« Reply #1 on: May 06, 2006, 07:21:42 PM »
NOLAN78F - check out the parts diagrams at crotchrocket.com   I think your headlight and directionals might be specific to your bike and year but you can verify that  with a little digging on that site also.
« Last Edit: May 06, 2006, 07:35:25 PM by upperlake04 »
NOLAN78F
« Reply #2 on: May 06, 2006, 07:59:20 PM »
thanks for the reply! it seems that when the windshield was put on, the headlight mounts off the forks were removed and i can not clearly see how i can replace it from that site.
Offline 78 k550
« Reply #3 on: May 06, 2006, 08:12:06 PM »
the 77-78 F's are the only one that used the ears that slant up like that. I dont think it will clear the disc brake proportioning valve up front if you use the other model's that dont angle up so much.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
NOLAN78F
« Reply #4 on: May 07, 2006, 11:53:51 AM »
thanks for the reply Paul,
 how do the ears mount to the forks, and how can i replace them?
« Reply #5 on: May 07, 2006, 12:31:01 PM »
The triple tree clamps for the fork tubes are loosened, and the fork tubes are withdrawn from the trees.  The upper fork covers are then put in place (along with the rubber isolation grommets) between the upper and lower trees, and the fork tubes reinstalled.
NOLAN78F
« Reply #6 on: May 07, 2006, 01:26:33 PM »
thanks now i understand how the ears/covers are attached.
 as far as the headlight compatability with other years and models k-f-a
I found a  1978 HONDA CB 750 A / Hondamatic HEADLIGHT relativitly cheap. does anyone know if it would fit ok. thanks
Offline scondon
  • Mmmm......tasty bugs
« Reply #7 on: May 07, 2006, 01:44:17 PM »
On the 78 F model the headlight shell has two openings in the back to allow all the wiring to route into the "rats nest" behind the headlight. Earlier model bikes(76 and under?) have only one opening, I think, as some of the electrics route into a box on the front of the frame. I'm sure the 78 750A headlight will fit but I'd make sure it has two openings in back or your wiring will be quite cramped.
