Author Topic: 750 exhaust confusion  (Read 502 times)
Offline fmctm1sw
« on: August 25, 2011, 06:16:13 PM »
I have a K3 and I'm looking at exhaust options.  From parts fische, I can tell there are differences between the K3 and later (K8 specifically) where the headers connect to the cylinder head.  The exhaust currently on the bike doesn't have the K3 exhaust collars as there should be a hex bolt in the bottom of the collars.  In short, what are my exhaust options with this?  Is the hardware that mounts the header pipes to the cylinder head interchangeable?
*edit.  Ah, I screwed that up.  Corrected K8 exhaust fische photo....*
« Last Edit: August 25, 2011, 06:25:04 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Re: 750 exhaust confusion
« Reply #1 on: August 25, 2011, 07:00:03 PM »
Is that a K3 engine mate? I only ask because it looks like it's been painted black. Anyway, someone has fitted an exhaust system designed for a later model CB750 to your bike, using mounting hardware from a later (probably K7/8 or F) model bike.
You can easily return it to stock, using the parts listed in your parts manual. I've fitted later model exhausts to earlier engines and vice versa, with no problems, just by changing the mounting hardware. Cheers, Terry.  ;D
Offline fmctm1sw
« Reply #2 on: August 26, 2011, 08:04:51 AM »
Terry, yes it's a K3 with a multitude of "PO induced" modifications.  I'm getting it (mostly) back to a stock look.  The engine is going to come out to remove the paint.  At least the frame rails aren't cut...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: August 26, 2011, 08:21:33 AM »
That is a 72 ir earlier head. some early K# still used them though.
 What month on your build tag?
Offline fmctm1sw
« Reply #4 on: August 26, 2011, 08:55:16 AM »
Something 1972 IIRC.  I'll have to look when I go home...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #5 on: August 26, 2011, 04:39:23 PM »
It's 11/72.  How do I tell the difference in the heads?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
