Author Topic: larger front bolt on rotor?  (Read 471 times)
Offline m in sc
« on: August 26, 2011, 06:21:14 AM »
is there a larger full floating modern rotor that shares the same bolt pattern as the CB? i plan on using adiffernt caliper anyway so...?  thanks.
Re: larger front bolt on rotor?
« Reply #1 on: August 26, 2011, 06:26:22 AM »
what does your different caliper fit?
Offline Bodi
« Reply #2 on: August 26, 2011, 06:39:25 AM »
You run into lots of challenges doing this. Particularly, modern calipers have pistons on both sides of the rotor: the wheel spokes are fairly close to the stock "floating" single piston caliper and you don't have enough clearance for double sided calipers.
As I recall, all the bike's I've seen with updated brakes (floating disks and multipiston calipers) use the entire front end of a donor bike, or at least the wheel/disk assembly. Cast or comstar type wheels are pretty much required, the original wheel's spokes are too wide at the caliper location.
Offline m in sc
« Reply #3 on: August 26, 2011, 06:49:35 AM »
do ti all the time on rd's w/spoke rims, FZR rotors and ducati monster rotors bolt on. my H1 has an R1 rotor on it, etc albeit that has a mag on it.
with the larger rotor, then the spoke clearance isnt an issue as much. i have a few 6 piston tokicos and and some FZR calipers + other ones. I can make any fit, just trying to avoid making an adapter for the rotor. do any of the CBR rotors share the rotor bolt pattern?
Offline m in sc
« Reply #4 on: August 26, 2011, 04:43:13 PM »
bump? anything before i fire up the mill?
