Author Topic: Any one know how to troubleshoot a LP generator (hurricaine comming!)  (Read 865 times)
Offline cb550inct
  • I am really good at buying parts
My Geration just cranks wont turn over. Going to put a new plug in, check oil ( iwas told they have a sensor, too low on oil and they wont crank)
Briggs and Stratton Vanguard 16hp running on LP
« Last Edit: August 26, 2011, 09:58:50 AM by Bob Wessner »
1978 cb550k
1998 Harley Springer Softail
2004 Harley Heritage Softtail (sold)
2001 Vespa 150 (sold)
1980 Kawasaki Kx 80  (first Bike)
Offline SaskCB500
Re: Amy one know how to troubleshoot a LP generator (hurricaine comming!)
« Reply #1 on: August 26, 2011, 08:28:18 AM »
My experience tells me that if you have proper oil levels then it's usually bad gas or dirty carb. check plug is clean and providing spark but most of the time my generator does the same because the carb..especially if I haven't run it in a while.
good luck and stay safe.
« Reply #2 on: August 26, 2011, 08:46:46 AM »
You will not have a gummed up carb with LP gas. Check your spark and make sure your regulator is allowing gas flow. Spark of course is primary. I see LP gas units, what I need is a Natural Gas unit. Good luck to you in CT, I am in NY and i think we are both gonna need those generators.
bollingball
« Reply #3 on: August 26, 2011, 08:47:18 AM »
First off to me cranks means it will turn over but will not start or run is this what is happening? Mine has a low oil level shut off also if you know you have oil then jump out the Sw.. It depends if it is a NO or NC Sw try taking the wire off the Sw. and see it you have fire to the plugs. Even though it is LP you can spray some starting fluid in the air filter to see if it tries to fire. That will tell you if it is a fuel or spark issue. I know what you are up against started mine yesterday ran it for a hour but I do that once a month. That was my MOS 52b3p in the Army  in the 60s. Try what I wrote and get back if it does not work.
                 Ken
« Last Edit: August 26, 2011, 08:49:45 AM by bollingball »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: August 26, 2011, 09:08:12 AM »
Can't help with your problem, but stay safe. I was born and raised on the south shore of Long Island, glad I'm not there now.
KingCustomCycles.com
« Reply #5 on: August 26, 2011, 09:54:14 AM »
Who's Amy ?
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Any one know how to troubleshoot a LP generator (hurricaine comming!)
« Reply #6 on: August 26, 2011, 09:56:14 AM »
Amy one here- no, can't help you on this one.
« Last Edit: August 26, 2011, 09:58:29 AM by Bob Wessner »
Offline cb550inct
« Reply #7 on: August 26, 2011, 10:38:33 AM »
Thanks For the Help, I went out at lunch and bought a new battery and plugs. I will work on it tonight. Im thinking it the oil level I bought 2 quarts.
Earthquakes and hurricanes in the northeast, The lamb has broken the seventh seal
1978 cb550k
Offline WarwickE36
« Reply #8 on: August 26, 2011, 04:54:37 PM »
Tough it out guy.   ::)   Good luck with the generator.  Im stealing my bosses if it gets bad enough here, plus enough ice to keep a keg cool for 3 days.  I keeps it real!
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline cb550inct
« Reply #9 on: August 27, 2011, 06:29:57 AM »
Got it working...new plugs, oil change working great
Looks like this will not be that bad thought. I plan on loosing a tree or two
1978 cb550k
Offline cb550inct
« Reply #10 on: August 29, 2011, 09:18:03 AM »
Was not that bad. Lost alot of trees, but never lost power.
1978 cb550k
« Reply #11 on: August 29, 2011, 10:14:37 AM »
Not to hijack but anyone have experience in converting a gasoline generator into a natural gas unit?
Offline cb550inct
« Reply #12 on: August 29, 2011, 10:21:29 AM »
It can be done, mine is on lp, there is a youtube video on how to do it.
Check it out
1978 cb550k
