Author Topic: Air screw o-rings for PD carbs + aftermarket float needles  (Read 782 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 27, 2011, 04:32:49 PM »
Anyone know if you can get these separate from the kits? All four of mine were squashed.. one was totally trashed. '77 750F carbs.
Also, I'd ordered a couple of new aftermarket float needles because my #2 carb kept overflowing a while back. I replaced it about a month ago. Then, today, when I pulled the carbs apart, the rubber tip of that needle had fallen off and was still up in the float seat. Is this common? And can you get OEM without buying the whole set?
« Last Edit: August 27, 2011, 04:36:20 PM by Tugboat »
Offline Kevin400F
Re: Air screw o-rings for PD carbs + aftermarket float needles
« Reply #1 on: August 28, 2011, 06:15:31 AM »
Hey Tug.....
I have some O-rings that are 2.6mm ID x 1.2mm cross-section.  Do you know what size the air screw rings are?
Kevin
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: August 29, 2011, 08:35:57 AM »
I've been searching but I can't find the measurements. They're REALLY small.. that's all I know. :)
bollingball
« Reply #3 on: August 29, 2011, 04:26:52 PM »
Tug Everything you need is here scroll around they come 25 to a bag and fit perfect.little washers also
http://www.siriusconinc.com/search_result.php?make=1&model=cb750&part=1&partno=&search=search&x=68&y=14&start=75
Offline Kevin400F
« Reply #4 on: August 29, 2011, 04:35:50 PM »
Tug, per the Sirius site, the ones I have should work for ya, if your interested in spending a couple of bucks for four rings versus $25 or so for a lifetime supply.
Shoot me an e-mail at kthunter01@sbcglobal.net
Kevin
bollingball
« Reply #5 on: August 29, 2011, 04:36:17 PM »
If you want to PM your address I will put a few in an envelope. No charge :) I have never had a tip come off but have a spare to throw in. Mine is a 78 but the parts are the same.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: August 30, 2011, 07:14:10 AM »
You guys are the best. Looks like I've got some karma to pay back :)
Offline Scott S
« Reply #7 on: August 30, 2011, 12:52:20 PM »
 Do the PD series carbs on the 550's have these O-rings, too?
 I've yet to pull my carbs, but I'm wondering if there was an air leak there, couldn't it cause some high idle and hanging idle problems?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
