Author Topic: Battery Issues  (Read 583 times)
BeAtheistItsFun
Battery Issues
« on: August 29, 2011, 07:08:58 PM »
My cb550k doesnt seem to want to hold a charge... ive had some trouble getting it started due to a bad choke cable, i think. but when trying to get it started the battery dies after a few attempts to get it started. is this normal, or is it a bad battery, or a short somewhere?
bollingball
Re: Battery Issues
« Reply #1 on: August 29, 2011, 07:29:01 PM »
Check the voltage at the battery at 4000rpm
Offline vozzy
Re: Battery Issues
« Reply #2 on: August 30, 2011, 04:41:32 AM »
How old is this battery? Is it maintenance free, or does it have caps on it?
Offline TicoCafe
Re: Battery Issues
« Reply #3 on: August 30, 2011, 08:19:33 AM »
If the battery condition in unknown...you are better sourcing a known good one (or new) to start in order to have a good starting point to perform checks on all electrics.  If you have a known good battery then you can start the process of elimination as you go through you electric test checklist.
You may want to source a good volt-multimeter too...
Pura Vida!
BeAtheistItsFun
Re: Battery Issues
« Reply #4 on: August 30, 2011, 12:00:11 PM »
good advice i think that is what i am going to do, the PO said it was new but it has no brand/markings of any kind so i think ill just start from the ground up..
KingCustomCycles.com
Re: Battery Issues
« Reply #5 on: August 30, 2011, 12:13:18 PM »
What is the voltage at 4000 rpm?  If you have never used a multimeter, now is a good time to start.  The skill will pay for itself in about 30 seconds.
BeAtheistItsFun
Re: Battery Issues
« Reply #6 on: August 30, 2011, 12:35:14 PM »
the bike is not in a fit state to run at the moment seeing as the carbs are in a box :P
as soon as i get it back to running ill check and a mechanic at my work is helping me with the bike bc he is a really big bike nut, ill have him show me the ropes with a multimeter
Re: Battery Issues
« Reply #7 on: August 30, 2011, 01:11:25 PM »
I would hate to see you buy a new battery needlessly if the charging system is kaput (technical term) and the battery can be saved with a slow, overnight charge.
