Author Topic: Cam Chain Ideas???  (Read 6692 times)
Offline dergs713
Cam Chain Ideas???
« on: August 30, 2011, 05:34:30 pm »
I ordered a new cam gear and chain for my 75 550. The prob is the woman at honda ordered me an extra link instead of a master link. Where can I find a breaker for this app.  Or if anyone has any other ideas on getting this new chain on so i can Finnish the assembly, it would be greatly appreciated.  I wanna ride it this season!
Anything would help!
 Thanks,
Matt
Re: Cam Chain Ideas???
« Reply #1 on: August 30, 2011, 05:45:40 pm »
 Thanks,
Matt
You probably got the right parts. The stock chain is an endless chain. The way to put it on involves removing the crank. Complete engine teardown.
The shortcut involves the master that looks like a link, is a "rivet" master link. You are to cut the chain, thread it thru, then install the master using a rivet link tool ($85+/-).
http://www.z1enterprises.com/Cam-Chain-BreakerRiveter-Tool-4011.aspx
With some skill and knowledge of technique you can peen the ends of the link over without the tool, using a hammer and small chisel.
Completely bummed? Now what?
« Last Edit: August 30, 2011, 05:51:13 pm by MCRider »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: August 30, 2011, 05:59:30 pm »
When I replaced my cam chain, I just took the bottom half, the new chain and a new master to my local semi-retired Honda mechanic.  He has the tools and decades of experience doing what MCRider describes.  He had it done in 15 minutes and charged me $35.  win win
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline fmctm1sw
« Reply #3 on: August 30, 2011, 06:18:14 pm »
Over on the twins site, a guy claims he was told by the manufacturer that since these are solid links (as opposed to hollow), they get pressed on and not peened.  Mine was pressed on with a pair of vice grips...
Heres the quote:
I have replaced the cam chains in a 1971 CB450, and 1973 CB450. Purchased both with master link from Z1.  I also received an unbroken 128 link chain. The new chain needs to be broken (one link removed). After correctly threading new chain through engine and head, install new master link, (total chain links now returned to 128).  Note: After installation of first chain I almost destroyed the new master link trying to flange the master link posts per maint. manual. Called Z1 who contacted the maker of the new chain. Informed old orginal master link had hollow posts that needed flanged to keep the link plate in place. The new master link for the new 219h chain has solid posts and the link plate needs to be pressed over solid posts and is a pressure fit. To help with this process I purchased from Z1 the Chain breaker they recommened, also worked great to pressure fit the master link plate over master link posts.
« Last Edit: August 30, 2011, 06:21:49 pm by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #4 on: August 30, 2011, 06:27:08 pm »
I'd need more confirm than that, even though they got a response from the manufacturer. I'd have to get two or 3 responses confirming that you don't peen the ends over. My expereince was it is a press fit AND and peening/flaring of the ends.
Offline fmctm1sw
« Reply #5 on: August 30, 2011, 06:36:04 pm »
I''ll find out when my 550 gets on the road I guess.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #6 on: August 30, 2011, 06:38:46 pm »
It would be difficult to flare it if there is no dimple in the end of the post, gotta admit. I wonder what the posts look like on a drive chain. Its a press and Flare install. I'll go look.
Offline scunny
  • don't call me expert
« Reply #7 on: August 31, 2011, 12:30:02 am »
I've seen both types. the "soft" link has dimpled ends which are flared over to hold the plate, the ends are usually a diferent colour. the hard link has no dimples and is a press fit, that's what is in my baby. I was unsure about the installation so went and saw an engineer who deals in chains and he said press fit only for the hard link. if you try and peen the ends over, there is a risk of bending the pins.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #8 on: August 31, 2011, 06:12:13 am »
Interesting.  :)
Offline dergs713
« Reply #9 on: September 03, 2011, 10:38:06 am »
Well heres what I ended up doing:
 I took a chain breaker tool, and took one of the press plates out and replaced one side with a ball bearing.
 First I pressed the chain together w a vise grip so it was holding by itself.
 Then I took the chain breaker with the bearing in on of the sides and cranked away.
    (By putting pressure on the pin between the ball bearing and the flat side, little by little, due to the amount of preasure, you can see the pin start to mushroom out.)
From what I heard "Its an old motorcycle trick" i was told, so let see if it holds.  The chain is not bent, theres no issues with flex, and the pin cannot be pushed out.  So hopefully this old trick worked!
Thanks for all the imput guys on the forum!
Goodluck to all!
Matt
Offline VTCBike750
« Reply #10 on: July 24, 2012, 08:14:27 pm »
Dergs,
How'd things work out?
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline CycleRanger
  • No comment about being an
« Reply #11 on: July 24, 2012, 08:48:24 pm »
Here's what Honda used way back when.
Do you have a copy of the Honda Shop Manual for your bike? Get one here:
« Reply #12 on: July 25, 2012, 06:15:01 am »
CR: Can you post that to the pinned thread in this forum about service bulletins?
« Reply #13 on: July 25, 2012, 01:01:26 pm »
Maybe a good idea to open the engine and replace the primary chains with tensioner too?
If the cam chain need to be replaced the internals must be tired too
CB750 K6-76 1005cc JMR Billet block.
